.NET
Active Member
wes.newman
Message 1 of 5 (2,001 Views)
Convert Arcs to Polylines
2001 Views, 4 Replies
06-25-2011 08:24 AM
I've got ObjectIds of a bunch of arcs that I need to convert to polylines for further processing.
Anyone know of a clean way to do this?
I was thinking of using the COM interface and sending the PEDIT command and converting the arcs.
The only problem is I don't know of a way to put the objectids into a selection set, then call the pedit command and use the previous selection.
Anyone know of a way to do this?
Wes
Here's something I did when I was learning, hope it helps.
 [CommandMethod("Arc2Poly")]
public void arc2poly()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
PromptSelectionOptions psOpts = new PromptSelectionOptions();
psOpts.MessageForAdding = "\nSelect arcs to convert: ";
psOpts.MessageForRemoval = "\n...Remove arcs: ";
TypedValue[] filter = { new TypedValue(0, "ARC") };
SelectionFilter ssfilter = new SelectionFilter(filter);
PromptSelectionResult psRes = ed.GetSelection(psOpts, ssfilter);
if (psRes.Status != PromptStatus.OK)
return;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
foreach (ObjectId id in psRes.Value.GetObjectIds())
Arc arc = (Arc)tr.GetObject(id, OpenMode.ForWrite);
Polyline poly = new Polyline();
poly.AddVertexAt(0, new Point2d(arc.StartPoint.X, arc.StartPoint.Y), GetArcBulge(arc), 0, 0);
poly.AddVertexAt(1, new Point2d(arc.EndPoint.X, arc.EndPoint.Y), 0, 0, 0);
poly.LayerId = arc.LayerId;
btr.AppendEntity(poly);
tr.AddNewlyCreatedDBObject(poly, true);
arc.Erase();
tr.Commit();
private double GetArcBulge(Arc arc)
double deltaAng = arc.EndAngle - arc.StartAngle;
if (deltaAng < 0)
deltaAng += 2 * Math.PI;
return Math.Tan(deltaAng * 0.25);
Jeff_M
Message 2 of 5 (1,995 Views)
Re: Convert Arcs to Polylines
06-25-2011 09:32 AM in reply to: wes.newman
                return;
                    arc.Erase();
                tr.Commit();
            if (deltaAng < 0)
Moderator
Alexander.Rivilis
Message 3 of 5 (1,983 Views)
06-25-2011 11:14 AM in reply to: Jeff_M
And:
poly.Normal = arc.Normal;
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
wes.newman
Message 4 of 5 (1,980 Views)
06-25-2011 11:18 AM in reply to: Jeff_M
Jeff,
Just what I was after.
Thanks!!
Wes
Active Member
wes.newman
Message 5 of 5 (1,978 Views)
06-25-2011 11:21 AM in reply to: Alexander.Rivilis
Thanks for the update.
