.NET
Convert AEC-Dimension into simple linear Dimension by c#
2 REPLIES 2
anikakramer2006
482 Views, 2 Replies
is it possible to convert AEC-Dimensions into linear Dimensions by C#?
We are using AutoCAD Architecture 2013 and want to switch
back to AutoCAD. We have to convert a lot of drawings.
I know you can convert AEC-Dimensions over the toolpalette
Dimension by Dimension
but is there a way to convert a hole Drawing?
Any suggestions?
Cheers,
Ani
2 REPLIES 2
Hi Ani,
I am checking with my colleagues who have AEC expertise. I will let you know if I can get some feedback.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Hi Ani,
Could you try exploding?  You may need to explode a few times as it might first create a block.  From my quick test in the UI, it seems to create AutoCAD dimentions.
I hope this helps.
Mikako Harada
”Boost
