.NET
Amremad
Message 1 of 5 (224 Views)
Connection
224 Views, 4 Replies
02-18-2013 06:13 AM
How Can i connect my Function in vb.net with autocad command (in drawing)
thx
You will compile your program into a class library. dll file.
You can use the netload command to load the file. or use the registry to automatically load them.
<CommandMethod("Command_here")>
http://www.autodesk.com/developautocad
or
purchase VB.NET For AutoCAD 2010
http://www.vbcad.com/
If you want to know how to get started.
arcticad
Message 2 of 5 (221 Views)
Amremad
Message 3 of 5 (178 Views)
Re: Connection
02-18-2013 11:15 PM in reply to: arcticad
Mr. arcticad
thank you for helping me
but i have other questions
- i will compile my vb.net project to exe file or what?? and where can i put it to run ??
<CommandMethod("CheckForPickfirstSelection", CommandFlags.UsePickSet)> _
Public Sub CheckForPickfirstSelection()
End Sub
 in this code where the command letters where can i write in the autocad command
i think i have confilict with understaning this way
Moderator
Alexander.Rivilis
Message 4 of 5 (171 Views)
Re: Connection
02-19-2013 03:20 AM in reply to: Amremad
Ok! Let start reading from start point:  http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/files/WS1a9193826455f5f...
Create new project
Load an Assembly to AutoCAD
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
arcticad
Message 5 of 5 (162 Views)
Re: Connection
02-19-2013 06:21 AM in reply to: Alexander.Rivilis
or
(defun botsbuildbots() (botsbuildbots))
