.NET
Hallex
Message 11 of 14 (316 Views)
Re: Connecting to AutoCAD
03-03-2012 02:44 PM in reply to: cvaught
Both ways is woking for me with A2009 Win7
Try again
{code}
   ''1st way
  Private Function GetAcadVer() As String
        Dim acadver As Object
        Try
            acadver = My.Computer.Registry.GetValue("HKEY_CLASSES_ROOT\AutoCAD.Application\CurVer", _
                                                  String.Empty, String.Empty)
            If TypeOf acadver Is String Then
                'MessageBox.Show("String acadver: " & acadver.ToString())
                Return acadver.ToString()
            Else
                Return Nothing
            End If
        Catch
            Return Nothing
        End Try
    End Function
    Public Sub connectAutoCad()
        Dim acApp As Object = Nothing
        Dim progID As String = GetAcadVer()
        Try
            'try to get a current instance of AutoCAD
            acApp = Marshal.GetActiveObject(progID)
        Catch
            'try to create a new instance of AutoCAD
            Dim acType As Type = Type.GetTypeFromProgID(progID)
            acApp = Activator.CreateInstance(acType, True)
        End Try
        acApp.GetType().InvokeMember("visible", Reflection.BindingFlags.SetProperty + Reflection.BindingFlags.IgnoreCase, Nothing, acApp, New Object() {True})
        acApp.GetType().InvokeMember("eval", Reflection.BindingFlags.InvokeMethod + Reflection.BindingFlags.IgnoreCase, Nothing, acApp, New Object() {"MsgBox(" + """Hello Discussion group""" + ")"})
        acApp.GetType().InvokeMember("quit", Reflection.BindingFlags.InvokeMethod + Reflection.BindingFlags.IgnoreCase, Nothing, acApp, Nothing)
        Marshal.FinalReleaseComObject(acApp)
        acApp = Nothing
    End Sub
''2nd way
   Private Sub GetAcadApp(ByVal AcadString As String)
        Dim AcadApp As Object = Nothing
        Try
            AcadApp = GetObject(, "AutoCAD.Application." & AcadString)
        Catch
            AcadApp = CreateObject("AutoCAD.Application." & AcadString)
            AcadApp.GetType().InvokeMember("Visible", Reflection.BindingFlags.SetProperty + Reflection.BindingFlags.IgnoreCase, Nothing, AcadApp, New Object() {True})
            MessageBox.Show(AcadApp.GetType().InvokeMember("Name", Reflection.BindingFlags.GetProperty + Reflection.BindingFlags.IgnoreCase, Nothing, AcadApp, Nothing).ToString)
        Finally
            AcadApp.GetType().InvokeMember("Quit", Reflection.BindingFlags.InvokeMethod + Reflection.BindingFlags.IgnoreCase, Nothing, AcadApp, Nothing)
            Marshal.FinalReleaseComObject(AcadApp)
            AcadApp = Nothing
        End Try
    End Sub
''example:
''on button click call
'' GetAcadApp("17")
{code}
~'J'~
cvaught
Message 12 of 14 (310 Views)
03-03-2012 07:56 PM in reply to: Hallex
Still doesn't work.  Just to confirm, did the code you use work with just one version of AutoCAD or have you been able to use it to connect to different versions on different machines using the same executable?
Hallex
Message 13 of 14 (304 Views)
03-04-2012 03:45 AM in reply to: cvaught
I'm working nowhere, sorry
just tested this code on my home machine - A2009(eng) release
Active Member
Hui-lung.Chen
Message 14 of 14 (200 Views)
10-07-2012 10:24 PM in reply to: cvaught
cvaught wrote:
Same problem still exists.  It starts acad.exe but cannot connect to it.  Any other opitons?  This seems like it should be pretty straight forward.  How else can a stand along application support multiple versions of AutoCAD?
There is no way that the same exe can support multiple versions of AutoCAD.
Different version or OS (X64 ,X86) of AutoCAD has different library.
The best way is to recomplie another project (the same code but has different reference librayies).
Huilung Chen
