.NET
Conflict when aliasing an Autodesk namespace
6 REPLIES 6
jbooth
527 Views, 6 Replies
After upgrading to the 2010 libraries, using the following code:
{code}Imports AcDb = Autodesk.AutoCAD.DatabaseServices{code}
Generates the following compiler error:
{code}Imports alias 'AcDb' conflicts with 'Structure AcDb' declared in the root namespace.{code}
I did not have this problem when referencing the old libraries (2008/R17.1). I'm currently using the alias AcDb2, which works - although I would prefer to use something more consistent with Autodesk's naming convention.
Could someone confirm that this is an issue, and if so, if anyone here found a way around it, aside from using an alternate alias?
JB
6 REPLIES 6
in reply to: jbooth
It may have something to do with your project, because
I can't repro that in C#.
AcDb is a native struct that's defined at the module-level
but it has internal scope, so it should not be visible to your
code.
Are you by chance using the Autodesk wizard?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6257888@discussion.autodesk.com...
JB
jbooth
in reply to: jbooth
No I did not use the wizard. This is a project built from scratch, referencing acdbmgd.dll, acmgd.dll, adwindows.dll, and the 2010 COM library.
jbooth
in reply to: jbooth
Update: I just tried to create a new blank project (dll file) and added only references to acdbmgd and acmgd.
Same problem. However I think I have an idea as to what's going on. I'm using Visual Studio 2005.
jbooth
in reply to: jbooth
Second update:
I downloaded the vs2010 beta and this problem still occurs, even when running on the .NET 4.0 framework. However, as Tony suggested, I created a C# project and it works fine.
So in conclusion, VB.NET does not work, and C# does. Has anyone else had this problem?
JB
in reply to: jbooth
Acdb exchange for something else.
For example: aaDb = Autodesk.AutoCAD.DatabaseServices
tp
"jbooth" escreveu na mensagem news:6257888@discussion.autodesk.com...
JB
jbooth
in reply to: jbooth
I already made it clear in my first post that using an alternate alias is not an answer I was looking for.
Thanks though,
JB
”Boost
