Hi ,
I am trying to deploy my DLL and during compilation , I got the below error.
------ Build started: Project: Practice, Configuration: Debug x86 ------
vbc : warning BC40010: Possible problem detected while building assembly 'Practice': Referenced assembly 'mscorlib.dll' targets a different processor
vbc : warning BC40010: Possible problem detected while building assembly 'Practice': Referenced assembly 'System.Data.dll' targets a different processor
Practice -> C:\VBProject\Practice\Practice\bin\x86\Debug\Practice.dll
------ Starting pre-build validation for project 'mySetup' ------
WARNING: Unable to find dependency 'ACMNUPARSER' (Signature='(null)' Version='18.1.0.0') of assembly 'AcCui.dll'
WARNING: Unable to find dependency 'MANAGEDMC3' (Signature='(null)' Version='4.11.0.0') of assembly 'AdWindows.dll'
------ Pre-build validation for project 'mySetup' completed ------
------ Build started: Project: mySetup, Configuration: Debug ------
Building file 'C:\VBProject\Practice\mySetup\Debug\mySetup.msi'...
ERROR: File 'AcTcMgd.dll' targeting 'AMD64' is not compatible with the project's target platform 'x86'
WARNING: File 'AcTcMgd.dll' targeting 'x64' is not compatible with the project's target platform 'x86'
Build process cancelled
========== Build: 1 succeeded or up-to-date, 1 failed, 0 skipped ==========
Can anybody help me in this regard? I am using Visual Studio 2010 and AutoCAD 2011. Windows 7 32-bit Operating System. Target CPU: x86. Target Framework: 3.5.
My registry settings is below:
HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R18.2\ACAD-A001:409\Applications\Practice
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A001:409\Applications\Practice
Regards
Zakir
Hi Zakir,
Sorry for the delay.
Have you tried netloading the dll into AutoCAD 2011 ?
Does it load ok and can you run the commands correctly ?
But, remember to set the .Net framework version to 3.5 for AutoCAD 2011.
Also, I see a few error messages indicating a mismatch in platform.
Have you tried building your project with "Any CPU" configuration ?
Hi Balaji,
Thanks for your kind response. I have solved this issue. There was mismatching of platform. now this is working fine.
Regards
Zakir
