.NET
Compiling C# Programs for different AutoCAD Versions ?
3 REPLIES 3
kosak956
573 Views, 3 Replies
I am considering to compile diverse C# .NET programs / modules for different versions of AutoCAD, namely 2006 and 2007 .
1.
What is the best way to do it in Visual Studio .NEt 2005,
without having to switch the Project References acdbmgd.dll and acmgd.dll for the different AutoCAD versions and verticals ?
2.
How can I configure the naming sheme ?
For example :
AutoCAD 2006 DLLs compile to :
Module1_2006.dll
Module2_2006.dll........
AutoCAD 2007 DLLs compile to :
Module1_2007.dll
Module2_2007.dll........
I know
It's rather VS 2005 and not .NET API Know-How but there are so many AutoCAD .NET gurus out there...!!!
One could propably help ?????
Thanks in advance
Konstantin
3 REPLIES 3
shambles
in reply to: kosak956
Konstantin
There are a couple of ways to handle this:
1. Use the tlbimp tool run against the AutoCAD type libraries to create your own interop assemblies and reference the generated assemblies from you app.
2. Use assembly re-directs either in the application configuration file or through the .Net Configuration console i.e. always compile against 2006 assemblies and use a re-direct when the app is deployed on a 2007 system.
I'm not sure how this pans out for 2006/2007, but we support 2004 - 2006 using the first method.
cheers
merv
cgay
merv,
Your #1 approach is what I would recommend, but I couldn't figure out how it would work.
Let's say you use tlbimp to generate an interop assembly for 2006 and 2007.
I would assume you would give each a unique namespace. i.e. AutoDesk.AutoCAD.2006 and AutoDesk.AutoCAD.2007
If this were the case, how would you declare an object of a specific type (say AcadApplication) and expect this to compile?
AutoDesk.AutoCAD.2006.Interop.AcadApplication AcadApp;
AutoDesk.AutoCAD.2007.Interop.AcadApplication AcadApp;
They share no inheritance. How do you do it without writing separate functions for each specific version of AutoCAD?
C
shambles
You only create an interop assembly using the 2006 typelibs - this means you cannot use new API features of 2007, but that's probably not going to be a big issue if you are supporting multiple versions. Like I say, I'm not sure how this pans out for 2006/2007, I'm assuming there have been no major changes to the typelibs. We have taken this approach using an interop assembly created against 2004 and it works for 2005 & 2006.
”Boost
