.NET
commandMethod quit working?
7 REPLIES 7
Message 1 of 8
386 Views, 7 Replies
I moved some code from .Net for 2006 over to Acad2007
and now none of my CommandMethods work while stepping
through code in the debugger. I just get "unknown command"
at the Acad prompt. What happened?
Perry
7 REPLIES 7
Message 2 of 8
> Perry
Nothing?
Message 3 of 8
cgay
Perry,
Your gonna have to give us some more info.
It sounds like AutoCAD is not loading your dll.
FYI, Include some example code. Better yet, a sample project, especially for a problem like this.
C
Message 4 of 8
CougerAC wrote:
> Perry,
> C
If Acad was'nt loading the dll, doesnt seem like I'd be able to step through it in the first place,
which I can, its just that if alt-tab over to Acad and type in a command name I just get a "unknown
command" rather than jumping back to the debugger at the appropriate command.
When not debugging, acad loads the dll (the debug version, there is no release version) and the commands
work.
I have defined them in code like this:
[CommandMethod("tbgather")]
public void add()
So what I have been doing is just place calls to the "commands" inside constructors
Message 5 of 8
wesbird
change to
public static void add()
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Message 6 of 8
weslleywang wrote:
> change to
Tried that, no difference.
Again, this only happens when stepping through code with the debugger
Message 7 of 8
cgay
Perry,
Try this....
http://jtbworld.blogspot.com/2006/04/debug-net-dlls-in-autocad-2007.html
C
Message 8 of 8
CougerAC wrote:
> Perry,
> Try this....
> C
THAT DID IT!!!!!!!
Thank you !!!!!
I'm gonna print that page and put it prominently into my binder
”Boost
