.NET
Distinguished Contributor
Patrick Johnson
Message 1 of 3 (190 Views)
commandmethod not working
190 Views, 2 Replies
11-07-2006 08:16 AM
Can someone take a look, I netload this dll and can not get the commandmethods to work.
Imports System
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Namespace Morton
Public Class Class1
Public Sub DrawingProperties()
Dim DP As DrawingProperties = New DrawingProperties
Application.ShowModalDialog(DP)
End Sub
Public Sub ViewSB1()
DrawingType("SHEETNO", "DType", "SB1")
End Sub
Public Sub DrawingType(ByVal strTag As String, ByVal strBlockName As String, _
Optional ByVal strTagValue As String = "", Optional ByVal strResult As String = "")
Dim DB As Database = HostApplicationServices.WorkingDatabase
Dim Trans As Transaction = DB.TransactionManager.StartTransaction
Dim BT As BlockTable = CType(Trans.GetObject(DB.BlockTableId, OpenMode.ForRead), BlockTable)
If BT.Has(strBlockName) Then
Dim btr As BlockTableRecord = CType(Trans.GetObject(BT(strBlockName), OpenMode.ForRead), BlockTableRecord)
Dim blockRefIds As ObjectIdCollection = btr.GetBlockReferenceIds(False, False)
If blockRefIds.Count > 0 Then
Dim br As BlockReference = CType(Trans.GetObject(blockRefIds(0), OpenMode.ForRead), BlockReference)
Dim attCount As Integer = br.AttributeCollection.Count
Dim i As Integer
For i = 0 To attCount - 1 Step 2
Dim ar As New AttributeReference
If (ar.Tag.Trim() = strTag) And (ar.TextString.Trim = strTagValue) Then
ar = CType(Trans.GetObject(br.AttributeCollection(i + 1), OpenMode.ForWrite), AttributeReference)
ar.TextString = strResult
End If
Next
End If
End If
Trans.Commit()
End Sub
End Class
End Namespace
thanks
pat
Patrick Johnson
Message 2 of 3 (189 Views)
Re: commandmethod not working
11-07-2006 08:19 AM in reply to: Patrick Johnson
I did have an attribute in front of the sub's
Public Sub DrawingProperties() (didnot copy over)
pat
Patrick Johnson
Message 3 of 3 (189 Views)
11-07-2006 08:36 AM in reply to: Patrick Johnson
found it
working directry not set
pat
