Also make sure that you are referencing the
aformentioned assemblies for the release or
product that your build targets.
If you are targeting multiple products/releases,
you have two options:
1. You need to do some manual manipulation of
the project file, to use build configuration-specific
conditions for project references. If you do that,
then you can have different build configurations
within the same project, with each targeting a
different release/product, and using the targeted
release/product's assemblies.
2 Create multiple projects, one for each targeted
product/release, and add the same source files to
each project (add them as linked files rather than
contained in the project folder), and then just set
each project's references to the assemblies from
the targeted product/release.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Tony Tanzillo" wrote in message news:5731740@discussion.autodesk.com...
Make sure that all of the AutoCAD assemblies
(e.g.,, acdbmgd.dll and acmdg.dll) that are
referenced in your project, have their 'CopyLocal'
property set to false.
wrote in message news:5731614@discussion.autodesk.com...
I have a library which i have continusouly built up over the last 2 years named MRPTools.dll
the library and it's references are designed to work in 2006. Now i'm having problems debugging, and using commands after i save a drawing.
this seems to have happened after having installed Civil 3D 2008. i have been starting to compile code with the 3D libraries, and ever since i recompiled my original code (still all referencing 2006) any command in my code won't run after saving.
So to try and explain it better. I have my library being demand loaded, it has event handlers which monitor the save/open/close events of a drawing, and write this data to a database. These event handlers continue to work even when the commands registered with CommandMethod don't.
i have the following on my machine, which may or may not be affecting what i'm doing:
Land Development Desktop (LDD) 2006 (primary program for drafting)
LDD 2007
Civil 3D 2008 which includes Land Desktop Companion 2008
all of these include some version of AutoCAD Map 3D
and i have MapGuide Studio 2008
If anyone has any ideas, i would greatly appreciate it.
