.NET
CommandFlags related (?) question
2 REPLIES 2
322 Views, 2 Replies
Hi all,
I need to make a command (which changes
database) that has some unusual properties:
1) can't be run by user from command window (can
get fired only by some other process)
2) can't get UNDOed
Is 1) possible at all?
Is 2) possible via certain CommandFlags
setting?
Maksim Sestic
2 REPLIES 2
There's no CommandFlags for any of that.
Also, there's no way to prevent undoing a given
operation, without also preventing any previous
changes from also being undone.
You can use the Control option of the UNDO
command to disable and then immediately enable
undo, keeping in mind that it will prevent undoing
of all previous changes, not only those you want to
prevent the user from undoing.
If you are doing something when a drawing file is
first opened, before the user has a chance to make
any changes to the drawing, then the aforementioned
UNDO/Control hack is one way to prevent undoing of
changes that your initialization code does.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Maksim Sestic" wrote in message news:5333873@discussion.autodesk.com...
Hi all,
I need to make a command (which changes database) that has some unusual properties:
1) can't be run by user from command window (can get fired only by some other process)
2) can't get UNDOed
Is 2) possible via certain CommandFlags setting?
Maksim Sestic
Thanks Tony, t
size=2>hat's what I found out for UNDO too.
I just didn't explain the reason for such strange
command behaviour. I had to make a command that gets fired out of Lisp script
(namely - acaddoc.lsp) as soon as drawing gets opened. It converts
drawing from version X to version Y of my application, changing DWG if
needed. I tried serveral things to make it work well out of managed assembly
responding to certain DocumentManager events, but that approach gets
tricky sometimes 🙂
Drawing conversion is
(naturally) UNDOable.
Maksim Sestic
size=2>
There's no
given
changes from also
being undone.
command to
prevent undoing
drawing file is
any
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
href="http://www.acadxtabs.com">
size=2>http://www.acadxtabs.com
size=2>"Maksim Sestic" <
face=Verdana size=2>info@geoinova.com
wrote in message
face=Verdana size=2>news:5333873@discussion.autodesk.com
face=Verdana size=2>...
Hi all,
1) can't be run
2)
can't get UNDOed
Is 2) possible
Maksim
Sestic
”Boost
