.NET
CommandFlags.localizedNameId ??????
2 REPLIES 2
245 Views, 2 Replies
Does anyone know what localizedNameId is?
It is not the localized name of the command. So, if not,
then what is it? Is it a resource ID ? If so, how does
that work?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
2 REPLIES 2
This is the id that is looked up in the satellite assembly of your main
assembly.
For example given the following
namespace A
class B
[CommandMethod(..."C"...)
public void test()
we will attempt to look up the string resource A.B.C in your satellite
assembly.
Albert
"Tony Tanzillo" wrote in message
news:4934432@discussion.autodesk.com...
that work?
Albert - Thanks. I reverse-engineered this by looking at AcLayer.
"Albert Szilvasy" wrote in message news:4941139@discussion.autodesk.com...
assembly.
namespace A
class B
public void test()
assembly.
Albert
that work?
”Boost
