.NET
ComboBox loses Handler
1 REPLY 1
171 Views, 1 Reply
I'm programming for AutoCAD 2006 using VS.NET 2003. I have 10 ComboBoxes using the same procedure, like this:
public sub ManageSelectedIndexChanged(ByVal sender As Object, ByVal e As EventArgs) Handles cb1.SelectedIndexChanged, cb2.SelectedIndexChanged......
What's happening is that, when I try to add a layer programmatically and that layer already exists, an exception is raise. So far so good. The problem is, when that error (or other error occures in a command) occur, my ComboBoxes stop to respond to the event SelectedIndexChanged!
I already tried to do a AddHandler when an error occur but it's useless, the Combos just stop working... Does anyone have a solution for this?
Thanks in advance fopr your help.
Filipe Marcelino
1 REPLY 1
I already solved this issue. It's a VS 2003 bug. Thanks anyway. I thought that maybe the error thrown by the AutoCAD was causing this but it wasn't.
Ragards,
Filipe Marcelino
”Boost
