.NET
Combining multiple drawings into a single drawing
5 REPLIES 5
896 Views, 5 Replies
I'm fairly new to the AutoCAD API for .NET, and for the last month or so I've been googling about, looking for comprehensive documentation on the Autodesk API (their equivalent of man pages). I've yet to find anything that describes each method and class in the API, so I turn to these forums for help.
My goal is this: I'm trying to figure out how to copy the contents of all drawings in the same directory into a single dwg file. Has anyone done this before, and if so, what subsets of the AutoCAD API should I use to do so?
I'm not asking someone to write this for me, only to point me in the right direction.
On a sidenote, If anyone has knowledge of where to find complete documentation for the API, I'd appreciate it.
5 REPLIES 5
Alfred.NESWADBA
I guess >>>that blog<<< contains the information (and most of the code) you look for 😉
The most complete documentation you'll find by downloading the ObjectARX-kit (from >>>here<<<, free, but to register). If it's just dotNET API (without a little left or right) you find it >>>here<<<. That is for 2010 (so ok for start), I haven't found an online-docu for 2013 yet.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Alexander.Rivilis
In addition that Alfred said I want to add this highly useful link to the blog: http://adndevblog.typepad.com/autocad
Insert Block from a different DWG using .NET
Adding an xref to a drawing (and converting attachments to overlays)
Facebook | Twitter | LinkedIn
Expert Elite Member
architectOfIdeas
i refer to the exchange quite a bit! it has great explanations of the api. it really helped me wrap my head around the use of the transaction manager and opening and closing objects.
kdub_nz
in reply to: Alfred.NESWADBA
@Alfred.NESWADBA wrote:
< .. >  If it's just dotNET API (without a little left or right) you find it >>>here<<<. That is for 2010 (so ok for start), I haven't found an online-docu for 2013 yet.
- alfred -
Alfred, This is the only one I've been able to find
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-4E1AAFA9-740E-4097-800C-CAED09CDFF12...
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Alfred.NESWADBA
in reply to: kdub_nz
Hi Kerry,
thanx for the link!
@Autodesk: also here the table of contents is missing and I think a wish from everyone using it!
- alfred -
Alfred NESWADBA
”Boost
