.NET
.NET
Member
catkinson89
Message 1 of 6 (460 Views)
Combining multiple drawings into a single drawing
460 Views, 5 Replies
01-03-2013 11:22 AM
I'm fairly new to the AutoCAD API for .NET, and for the last month or so I've been googling about, looking for comprehensive documentation on the Autodesk API (their equivalent of man pages). I've yet to find anything that describes each method and class in the API, so I turn to these forums for help.
My goal is this: I'm trying to figure out how to copy the contents of all drawings in the same directory into a single dwg file. Has anyone done this before, and if so, what subsets of the AutoCAD API should I use to do so?
I'm not asking someone to write this for me, only to point me in the right direction.
On a sidenote, If anyone has knowledge of where to find complete documentation for the API, I'd appreciate it.
Alfred.NESWADBA
Message 2 of 6 (450 Views)
Re: Combining multiple drawings into a single drawing
01-03-2013 11:43 AM in reply to: catkinson89
I guess >>>that blog<<< contains the information (and most of the code) you look for :smileywink:
The most complete documentation you'll find by downloading the ObjectARX-kit (from >>>here<<<, free, but to register). If it's just dotNET API (without a little left or right) you find it >>>here<<<. That is for 2010 (so ok for start), I haven't found an online-docu for 2013 yet.
- alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 3 of 6 (445 Views)
01-03-2013 12:07 PM in reply to: catkinson89
In addition that Alfred said I want to add this highly useful link to the blog: http://adndevblog.typepad.com/autocad
Insert Block from a different DWG using .NET
Adding an xref to a drawing (and converting attachments to overlays)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
architectOfIdeas
Message 4 of 6 (427 Views)
01-03-2013 01:37 PM in reply to: catkinson89
i refer to the exchange quite a bit! it has great explanations of the api. it really helped me wrap my head around the use of the transaction manager and opening and closing objects.
Valued Mentor
KerryBrown
Message 5 of 6 (388 Views)
01-05-2013 07:42 PM in reply to: Alfred.NESWADBA
alfred.neswadba wrote:
< .. >  If it's just dotNET API (without a little left or right) you find it >>>here<<<. That is for 2010 (so ok for start), I haven't found an online-docu for 2013 yet.
- alfred -
Alfred, This is the only one I've been able to find
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-4E1AAFA9-740E-4097-800C-CAED09CDFF12...
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Alfred.NESWADBA
Message 6 of 6 (378 Views)
01-06-2013 01:07 AM in reply to: KerryBrown
Hi Kerry,
thanx for the link!
@Autodesk: also here the table of contents is missing and I think a wish from everyone using it!
- alfred -
Alfred NESWADBA
