.NET
Active Member
svplaser
Message 1 of 7 (534 Views)
COM API vs .NET API ...
534 Views, 6 Replies
09-08-2012 09:28 AM
What is the difference between COM API and .NET API of autoCAD?
I thought we need to strictly use the transaction manager and add/delete entities from
Autocad's model space.
But the example in this link is not using "transaction" manager and this is still working.
http://howtoautocad.com/introduction-to-vb-net-in-autocad/
From the comments I learnt that this is using COM API instead of .NET API.
But I cant find any detail about this COM API.
What is this COM API? How is it different from .NET API?
Will it be supported in all versions of AutoCAD 2D?
regards
ADN Support Specialist
Balaji_Ram
Message 2 of 7 (488 Views)
Re: COM API vs .NET API ...
09-10-2012 07:29 AM in reply to: svplaser
Here is a blog post that might answer your questions :
http://through-the-interface.typepad.com/through_the_interface/2006/09/com_vs_net_in_a.html
If you are considering the differences for any new development, I strongly suggest using the AutoCAD .Net API especially if you are considering writing a plugin that runs inside AutoCAD. But for controlling AutoCAD from an external application, then COM API is the way to go.
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
svplaser
Message 3 of 7 (468 Views)
09-10-2012 08:11 PM in reply to: svplaser
Is the Autocad .NET developers guide available offline as a PDF or chm file?
It is available online at :
http://docs.autodesk.com/ACD/2011/ENU/filesMDG/WS1a9193826455f5ff2566ffd511ff6f8c7ca-4875.htm
( 2011, 2012, 2013 versions etc.) . But I need something offline.
regards
Viswesh
Balaji_Ram
Message 4 of 7 (428 Views)
09-13-2012 05:28 AM in reply to: svplaser
Hi Viswesh,
Have a look at arxmgd.chm, arxdev.chm and arxref.chm in the <ObjectARX folder>\docs.
Balaji
Active Member
svplaser
Message 5 of 7 (401 Views)
09-13-2012 08:43 PM in reply to: svplaser
Thanks for the replies. But Iam not getting an email alert when some one replies to my post!.
I do have the "Email me when someone replies" option ticked when submitting my post.
My registered id is : sales@svplaser.com
Not sure if this is problem with my mail id or with this forum?
regards
Active Member
svplaser
Message 6 of 7 (399 Views)
09-13-2012 09:01 PM in reply to: Balaji_Ram
Iam using autocad mechanical 2012 & VB express 2010.
Can I use ObjectARX2013 SDK or shud I stick to ObjectARX2012 SDK?
regards
Valued Mentor
KerryBrown
Message 7 of 7 (396 Views)
09-13-2012 09:07 PM in reply to: svplaser
regards
The SDK's are meant to be used for the version they are named after.
The distinction is compounded by the changes in the 2013 API.
class keyThumper<T> : Lazy<T>;      another  Swamper
Announcements
Need installation help?
