.NET
ColorDialog
10 REPLIES 10
Message 1 of 11
matus.brlit
844 Views, 10 Replies
ColorDialog
when i use Autodesk.AutoCAD.Windows.ColorDialog from a modeless form, the colordialog doesn't get focus, so you have to click twice to pick the color (the first click only sets focus to the dialog)
when i put the same code in a command and run it from commandline, it gets focus
        Dim cd As New Autodesk.AutoCAD.Windows.ColorDialog
        If cd.ShowDialog <> Windows.Forms.DialogResult.OK Then Exit Sub
10 REPLIES 10
Message 2 of 11
Hi, which version of AutoCAD are you using? I cannot see this behavior on 2012/Win7
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 3 of 11
in reply to: matus.brlit
Try this
        myPalette.KeepFocus = False
        Dim dr as DialogResult = cd.ShowDialog
        MyPalette.KeepFocus = True
        If dr <> Windows.Forms.DialogResult.OK Then Exit Sub
Hav'nt done any palette programming lately, but last time I did, you needed to manage the focus yourself for the palette. Should be plenty of examples, just search on the 'KeepFocus'.'
HomeBoy Out
Message 4 of 11
quigs
I
 have the exact same problem.  I am running Autocad 2011
My name is Martin.. 😄
Message 5 of 11
matus.brlit
to augusto: I'm using AutoCAD 2011, i will try it in 2012, but i don't have it installed here
to HomeBoy: I'm not opening the ColorDialog from palette, but from the Windows.Form
Message 6 of 11
hi,
I could not repro this here...I tried with modeless form using Application.ShowModelessDialog and Form.ShowDialog, but the ColorDialog is always working fine....if you manage to have a sample uploaded, I can take a look.
HomeBoy: I believe the issue you´re talking is related to combo boxes on palettes, not the case here. Or do you have something different?
Augusto Goncalves
Augusto Goncalves
Message 7 of 11
Augusto, are you trying to reproduce it on AutoCAD 2011?
i will extract the code from my project, so i can upload it
Message 8 of 11
matus.brlit
i found out, that it works fine, when i open the ColorDialog d\from button.click event, but wrong, when i open it from imagebox.click event
you can test it from the attached project
Message 9 of 11
I can see it now...
Apparently there is a limitation with PictureBox: it cannot receive focus. It seems that this is causing the problem we see here, so I would suggest you use a flat button with no border, which is visually equal a picturebox, but can receive focus and work in this case.
How that sounds?
Augusto Goncalves
Message 10 of 11
thank you, it works perfect
Message 11 of 11
quigs
in reply to: augusto.goncalves
That won't help me, as I have 450 picture boxes calling a color pallete.
Thanks as well any way for the help!
”Boost
