.NET
flongsworth
Message 1 of 8 (191 Views)
Color Selection Dialog
191 Views, 7 Replies
02-11-2006 02:26 PM
This is probably very simple but can anyone show me how choose a color from the dialog.
Dim ColorRes As Autodesk.AutoCAD.Colors.Color
Autodesk.AutoCAD.ApplicationServices.Dialogs.ChooseColorDialog(ColorRes, True, CurColor, Dialogs.ColorTabs.ACITab)
this gives me the following warning:
Warning 1 Variable 'ColorRes' is passed by reference before it has been assigned a value. A null reference exception could result at runtime.
*tp
Message 2 of 8 (191 Views)
Re: Color Selection Dialog
02-12-2006 03:22 PM in reply to: flongsworth
For instance:
Dim ColorRes As New Autodesk.AutoCAD.Colors.Color
or
Dim ColorRes As Autodesk.AutoCAD.Colors.Color =
Autodesk.AutoCAD.Colors.Color.FromColor(System.Drawing.Color.Black)
or
Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.None,
1)
or
Dim c As Autodesk.AutoCAD.Colors.Color =
Autodesk.AutoCAD.Colors.Color.FromRgb(255, 255, 255)
escreveu na mensagem news:5083997@discussion.autodesk.com...
the dialog.
flongsworth
Message 3 of 8 (191 Views)
02-12-2006 04:17 PM in reply to: flongsworth
I know you can declare the color in those ways, but I want to give the user the ability to use the color selection dialog to choose the color.
Distinguished Contributor
cgay
Message 4 of 8 (191 Views)
02-12-2006 09:01 PM in reply to: flongsworth
Hey flongsworth ,
I am pretty sure tp was giving you the solution to the error you posted. The warning you are getting is a compiler warning. I would also like to add one other possible fix:
Dim ColorRes As Autodesk.AutoCAD.Colors.Color = Nothing
Good Luck,
C
flongsworth
Message 5 of 8 (191 Views)
02-13-2006 06:11 AM in reply to: flongsworth
Thanks , and I apologize for not paying attention to tp's post. The samples you both provided work fine.
wesbird
Message 6 of 8 (191 Views)
02-14-2006 06:48 AM in reply to: flongsworth
Hi flongsworth:
I am looking for the code to show AutoCAD true color dialog and pick color from there for a while. When I read your message, I thought that what I am looking for. Is this correct?
Where did you find the ChooseColorDialog? I can not find it everywhere, include the help file.
I tried to compile the code:
[code]
[CommandMethod("AsdkCmd1")]
static public void AsdkCmd1() // This method can have any name
// Put your command code here
Autodesk.AutoCAD.Colors.Color ColorRes = new Autodesk.AutoCAD.Colors.Color();
Autodesk.AutoCAD.ApplicationServices.Dialogs.ChooseColorDialog(ColorRes, True, CurColor, Dialogs.ColorTabs.ACITab);
[/code]
which does not comiple with this error message:
...\ChooseColorDialogCS\Class.cs(52): The type or namespace name 'Dialogs' does not exist in the class or namespace 'Autodesk.AutoCAD.ApplicationServices' (are you missing an assembly reference?)
Is there something I missing?
Thank you
Wes
*Kerry Brown
Message 7 of 8 (191 Views)
02-14-2006 07:30 AM in reply to: flongsworth
Have you looked at :
Autodesk.AutoCAD.Windows.ColorDialog Class
wrote in message news:5085599@discussion.autodesk.com...
Hi flongsworth:
[code]
[/code]
Thank you
Wes
RonnieWilkins
Message 8 of 8 (191 Views)
02-14-2006 08:25 AM in reply to: flongsworth
No error catching but show how to use the color dialog...
Imports AcCm = Autodesk.AutoCAD.Colors
Imports AcWi = Autodesk.AutoCAD.Windows
Public Class ColorSelector
Public Function GetColor() As AcCm.Color
Dim CD As New AcWi.ColorDialog
Dim C As AcCm.Color = AcCm.Color.FromColorIndex(AcCm.ColorMethod.ByAci, 1) 'Set color to RED
CD.Color = C
CD.SetDialogTabs(AcWi.ColorDialog.ColorTabs.ACITab Xor AcWi.ColorDialog.ColorTabs.TrueColorTab) 'Do not show color books
If CD.ShowDialog <> DialogResult.OK Then
Return Nothing
End If
Return CD.Color
End Function
Public Function GetColor(ByVal DefaultColor As AcCm.Color) As AcCm.Color
CD.Color = DefaultColor
'User cancelled return default color
Return DefaultColor
End If
Return CD.Color
End Function
End Class
P.S. I have a widescreen monitor so I apologize in advance for scrolling. I'm not a big fan of continuation lines. Message was edited by: rwilkins
Ronnie Wilkins, Jr.
AMS CAD + CAFM Solutions
Sr. Solutions Developer
Autodesk Certified Instructor: Inventor
