.NET
Collection of loaded .Net applications
3 REPLIES 3
MRiemenCAD
678 Views, 3 Replies
Is there a collection object where I can iterate through loaded .net applications? Also, is there a programatic way to load .net apps from within another application? I would Like to use the registry to auto-load an initial app that then manages and loads other .net toolsets.
Thanks for any help in advance.
3 REPLIES 3
norman.yuan
in reply to: MRiemenCAD
You can load .NET DLL into AutoCAD with Syste,ReflectionAssembly.Load()/LoadFrom(). It does the same thing just as you load them by NETLOAD command in AutoCAD.
You can get the loaded .NET assemblies with the code below:
[CommandMethod("ListLoadedApplication")]
public void CmdListLoadedAssemblies()
  Document doc = Application.DocumentManager.MdiActiveDocument;
  Editor ed = doc.Editor;
  //get all loaded assemblies in the current appdomain
  System.Reflection.Assembly[] assemblies = System.AppDomain.CurrentDomain.GetAssemblies();
  foreach (System.Reflection.Assembly assembly in assemblies)
    //let's remove built-in .NET assemblies
    if (!assembly.Location.ToLower().Contains("windows"))
      ed.WriteMessage(assembly.Location + "\n");
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Thanks for posting. I appreciate your help.
”Boost
