.NET
Valued Contributor
MRiemenCAD
Message 1 of 4 (323 Views)
Collection of loaded .Net applications
323 Views, 3 Replies
08-28-2012 09:21 AM
Is there a collection object where I can iterate through loaded .net applications? Also, is there a programatic way to load .net apps from within another application? I would Like to use the registry to auto-load an initial app that then manages and loads other .net toolsets.
Thanks for any help in advance.
You can get the loaded .NET assemblies with the code below:
[CommandMethod("ListLoadedApplication")]
public void CmdListLoadedAssemblies()
  Document doc = Application.DocumentManager.MdiActiveDocument;
  Editor ed = doc.Editor;
  //get all loaded assemblies in the current appdomain
  System.Reflection.Assembly[] assemblies = System.AppDomain.CurrentDomain.GetAssemblies();
  foreach (System.Reflection.Assembly assembly in assemblies)
    //let's remove built-in .NET assemblies
    if (!assembly.Location.ToLower().Contains("windows"))
      ed.WriteMessage(assembly.Location + "\n");
norman.yuan
Message 2 of 4 (308 Views)
Re: Collection of loaded .Net applications
08-28-2012 12:08 PM in reply to: MRiemenCAD
You can load .NET DLL into AutoCAD with Syste,ReflectionAssembly.Load()/LoadFrom(). It does the same thing just as you load them by NETLOAD command in AutoCAD.
ADN Support Specialist
augusto.goncalves
Message 3 of 4 (265 Views)
08-30-2012 07:41 AM in reply to: MRiemenCAD
Augusto Goncalves
Autodesk Developer Network
Valued Contributor
MRiemenCAD
Message 4 of 4 (260 Views)
08-30-2012 07:43 AM in reply to: augusto.goncalves
Thanks for posting. I appreciate your help.
