.NET
BugWare
Message 1 of 4 (558 Views)
Closing AutoCAD from VB.NET
558 Views, 3 Replies
01-31-2014 12:22 PM
I am using VB.NET 2010 and AutoCAD OEM 2014 (though for Development I use regular AutoCAD 2014).  I run Visual Studio, and it opens AutoCAD automatically.  Then I NETLOAD my app, which opens a new vb.net form.  Then my user can draw different entitites onto the AutoCAD pallette.
Of course it's easy to close the VB form, but how can I close the full AutoCAD program programatically from my VB form?  I've tried AcadApp.Quit() from my VB form but it does nothing.
The reason that this is important not to leave it to the user to close it is that I check for a valid license from VB, and if there is none, I don't want the user to be able to continue to use AutoCAD.
Also, what/where is the reference manual to find examples of using VB.NET and AutoCAD?
thanks in advance!
Mitch
Micropaleontology
Oil Industry
That will probably work 99% of the time except if autocad is stuck on some command. I think Environment.Exit(0) will "brute force" close it no matter what.
Hallex
Message 2 of 4 (530 Views)
Re: Closing AutoCAD from VB.NET
02-01-2014 03:14 AM in reply to: BugWare
Handle Form_Closing event either for modal or modeless form:
private void Form1_FormClosing(object sender, FormClosingEventArgs e)
Autodesk.AutoCAD.ApplicationServices.Application.Quit();
Valued Contributor
sszabo
Message 3 of 4 (521 Views)
02-01-2014 06:43 AM in reply to: Hallex
BugWare
Message 4 of 4 (389 Views)
02-20-2014 06:29 AM in reply to: BugWare
Environment.Exit(0)  seems to work nicely, and I like the 'brute force' approach since the user no longer has valid use of the program if it reaches this point.  Thanks very much!
Micropaleontology
Oil Industry
