.NET
Close & Save
3 REPLIES 3
Babak
309 Views, 3 Replies
Close & Save
Is there any way to close all opened files (drawing files)?
How can I save a drawing file programmatically?
Thank you,
Babak
3 REPLIES 3
Matt S
in reply to: Babak
Below is a way to iterate through all open drawings and save, close and do other things. There has to be a better way to do this, but this was the easiest at the time.
[CommandMethod("DwgScale10", CommandFlags.Session)]
public void sveDwgScale10()
int i = 0;
Document curDoc;
DocumentCollection docCol;
docCol = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
foreach (Document doc in docCol)
docCol.MdiActiveDocument = doc;
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
doc.SendStringToExecute("scale all 0,0,0 10.0 ", false, false, true);
doc.SendStringToExecute("zoom e ", false, false, true);
doc.SendStringToExecute("qsave ", false, false, true);
doc.SendStringToExecute("close ", false, false, false);
Babak
in reply to: Babak
Thank you very much for your reply.
But what other better way? 😉 I need to save drawing automatically after each changes.
Thank you again,
Babak
NathTay
in reply to: Babak
Using the CloseAndSave method of Autodesk.AutoCAD.ApplicationServices.Document instead of resorting to SendStringToExecute.
Regards - Nathan
”Boost
