.NET
Close event 'Save Changes'
4 REPLIES 4
693 Views, 4 Replies
Hi all;
I am currently writing an ACAD app that writes data to a database when the user saves a drawing. I can do this on a save command by subscribing to the CommandEnded event as follows:
{code}
MdiActiveDocument.CommandEnded += new CommandEventHandler(MdiActiveDocument_CommandEnded);
void MdiActiveDocument_CommandEnded(object sender, CommandEventArgs e)
if (e.GlobalCommandName.ToUpper().Contains("SAVE"))
//Do work...
{code}
The problem I am having is when the user closes a drawing. I know I can intercept a close in the same manner as above through the BeginDocumentClose event. However, its the "Save Changes" prompt that occurs when the use closes after making changes that is causing my trouble. I can't figure how to determine whether the user has selected "Yes" or "No". Basically, I don't want to execute my save if the user has opted not to save the drawing; I only want to to execute my save if the user has selected "Yes".
Any help or thoughts on this would be greatly appreciated!
4 REPLIES 4
You shouldn't use the CommandEnded event for this.
The BeginSave event should fire regardless of how a save is done, but you
may also need to weed out AutoSave if you don't want to handle those.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6285443@discussion.autodesk.com...
Hi all;
{code}
//Do work...
{code}
Thanks Tony - that helps a lot!
The trouble I am having now relates to canceling the save. If my custom routine fails, I don't want to save the drawing. I have tried sending an escape character using SendCommand and also subscribing to the DocumentLockModeChanged and using the 'Veto' method - neither strategy seems to work. Here's my code so far (simplified of course):
{code}
bool _cancelSave = false;
void Database_BeginSave(object sender, DatabaseIOEventArgs e)
string[] input = { "SAVE", "SAVEAS", "QSAVE", "CLOSE" };
List validCommands = new List(input);
if (validCommands.Contains(MdiActiveDocument.CommandInProgress))
if (!doWork())
_cancelSave = true;
/* Or we could send escape:
* String esc = Convert.ToChar(Keys.Escape).ToString();
* SendCommand(esc, false);
void DocumentManager_DocumentLockModeChanged(object sender, DocumentLockModeChangedEventArgs e)
if (cancelSave)
e.Veto();
{code}
Again - any thoughts would be greatly appreciated!
Are you saying that if something goes wrong in your extension (e.g., a
software bug), the user should not be able to save the file at all ?????????
You're kidding right?
wrote in message news:6286027@discussion.autodesk.com...
Thanks Tony - that helps a lot! The trouble I am having now relates to
course): {code} bool _cancelSave = false; void Database_BeginSave(object
sender, DatabaseIOEventArgs e) { string[] input = { "SAVE", "SAVEAS",
"QSAVE", "CLOSE" }; List validCommands = new List(input); if
(validCommands.Contains(MdiActiveDocument.CommandInProgress)) { if
(!doWork()) _cancelSave = true; /* Or we could send escape: * String esc =
Convert.ToChar(Keys.Escape).ToString(); * SendCommand(esc, false); */ } }
DocumentLockModeChangedEventArgs e) { if (cancelSave) e.Veto(); _cancelSave
= false; } {code} Again - any thoughts would be greatly appreciated!
I hear ya - but yes that's the spec I'm working with at the moment. There will be a way the user can turn off that behavior if they have to, but by default that's the way it would work. Seems like it may not be possible, but I could be wrong.
”Boost
