.NET
Active Contributor
0 Kudos
Post 1 of 8
Clone block with points
287 Views, 7 Replies
07-21-2013 11:00 PM
I have a object which im cloning and moving along a path.I am finding the GeometricExtentsBestFit points of the block and plotting in the drawing.I want to clone the object with these points.Any idea on how to do this.Please help.
Dim bref As BlockReference = actran.GetObject(idsBox(0), OpenMode.ForWrite).
Dim BlockCloneNew As BlockReference = bref.Clone()
Dim bestFit AsExtents3d = bref.GeometryExtentsBestFit
Dim bestfitMin As Point3d = bestFit.MinPoint
Dim bestfitMax1 As Point3d = bestFit1.MaxPoint
Thanks in advance
Do you mean, you need to display the block reference clone and its extent points along the path ?
In that case, using transient graphics to show them might help.
Here is a sample code that you can try. When prompted select a block reference and a polyline path. The block reference is cloned and displayed along the path at sampled points.
Public Class Test
Implements IExtensionApplication
Private _markers As DBObjectCollection = Nothing
<CommandMethod("Test")> _
Public Sub TestMethod()
Dim activeDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = activeDoc.Database
Dim ed As Editor = activeDoc.Editor
Dim peo1 As New PromptEntityOptions("Select a block reference : ")
peo1.SetRejectMessage("Not a block reference")
peo1.AddAllowedClass(GetType(BlockReference), True)
Dim per1 As PromptEntityResult = ed.GetEntity(peo1)
If per1.Status <> PromptStatus.OK Then
Return
End If
Dim brefId As ObjectId = per1.ObjectId
Dim peo2 As New PromptEntityOptions("Select a polyline : ")
peo2.SetRejectMessage("Not a polyline")
peo2.AddAllowedClass(GetType(Polyline), True)
Dim per2 As PromptEntityResult = ed.GetEntity(peo2)
If per2.Status <> PromptStatus.OK Then
Return
End If
Dim plineId As ObjectId = per2.ObjectId
ClearTransientGraphics()
_markers = New DBObjectCollection()
Dim intCol As New IntegerCollection()
Dim samplePoints As New Point3dCollection
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim bref As BlockReference = TryCast(tr.GetObject(brefId, OpenMode.ForRead), BlockReference)
Dim pline As Polyline = TryCast(tr.GetObject(plineId, OpenMode.ForRead), Polyline)
If pline IsNot Nothing Then
Dim segCount As Integer = pline.NumberOfVertices
For cnt As Integer = 0 To segCount - 1
Dim vertexPt As Point3d = pline.GetPoint3dAt(cnt)
Dim type As SegmentType = pline.GetSegmentType(cnt)
Select Case type
Case SegmentType.Arc
Dim arc2d As CircularArc2d = pline.GetArcSegment2dAt(cnt)
Dim samplePts1 As Point2d() = arc2d.GetSamplePoints(5)
For Each pt2d As Point2d In samplePts1
samplePoints.Add(New Point3d(pt2d.X, pt2d.Y, 0.0))
Next
Exit Select
Case SegmentType.Line
Dim line2d As LineSegment2d = pline.GetLineSegment2dAt(cnt)
Dim samplePts2 As Point2d() = line2d.GetSamplePoints(5)
For Each pt2d As Point2d In samplePts2
Next
Exit Select
End Select
Next
End If
For Each pt As Point3d In samplePoints
Dim marker1 As BlockReference
marker1 = bref.Clone()
marker1.Position = pt
Autodesk.AutoCAD.GraphicsInterface.TransientManager.CurrentTransientManager.AddTransient(marker1, Autodesk.AutoCAD.GraphicsInterface.TransientDrawingMode.Highlight, 128, intCol)
_markers.Add(marker1)
Dim exts As Extents3d
exts = marker1.GeometryExtentsBestFit()
Dim marker2 As DBObject
'marker2 = New DBPoint(exts.MinPoint)
marker2 = New Circle(exts.MinPoint, Vector3d.ZAxis, 0.1)
Autodesk.AutoCAD.GraphicsInterface.TransientManager.CurrentTransientManager.AddTransient(marker2, Autodesk.AutoCAD.GraphicsInterface.TransientDrawingMode.Highlight, 128, intCol)
_markers.Add(marker2)
Dim marker3 As DBObject
'marker3 = New DBPoint(exts.MaxPoint)
marker3 = New Circle(exts.MaxPoint, Vector3d.ZAxis, 0.1)
Autodesk.AutoCAD.GraphicsInterface.TransientManager.CurrentTransientManager.AddTransient(marker3, Autodesk.AutoCAD.GraphicsInterface.TransientDrawingMode.Highlight, 128, intCol)
_markers.Add(marker3)
Next
tr.Commit()
End Using
End Sub
Private Sub IExtensionApplication_Initialize() Implements IExtensionApplication.Initialize
End Sub
Private Sub ClearTransientGraphics()
If _markers IsNot Nothing Then
For Each marker As DBObject In _markers
Autodesk.AutoCAD.GraphicsInterface.TransientManager.CurrentTransientManager.EraseTransient(marker, intCol)
marker.Dispose()
Next
End If
End Sub
Private Sub IExtensionApplication_Terminate() Implements IExtensionApplication.Terminate
End Sub
End Class
Active Contributor
0 Kudos
Post 2 of 8
Re: Clone block with points
07-22-2013 12:47 AM in reply to: gulzar25
Can someone suggest me on how to make the block and points as a single entity as mentioned above.
Thanks in advance
ADN Support Specialist
100 Kudos
Post 3 of 8
07-25-2013 02:32 AM in reply to: gulzar25
Public Class Test
            Return
        End If
            Return
        End If
                    Select Case type
                            Next
                            Exit Select
                            Next
                            Exit Select
                    End Select
                Next
            End If
            Next
            tr.Commit()
        End Using
    End Sub
    End Sub
                marker.Dispose()
            Next
        End If
    End Sub
    End Sub
End Class
Balaji
Developer Technical Services
Autodesk Developer Network
Active Contributor
0 Kudos
Post 4 of 8
07-25-2013 03:21 AM in reply to: Balaji_Ram
Hi Balaji,
Thanks a lot for the reply.I want to display block and its extent points along a path.But this should be placed with respect to 2 points on the block.So when i move the block at certain intervals it is sometimes at an angle wrt the path, in such scenarios the geometric extents is not coming correctly.So i want to calculate the geometricextents initially and treat points and block as one entity and clone.Is this possible.I hope i am clear.
Thanks in advance
100 Kudos
Post 5 of 8
07-25-2013 04:34 AM in reply to: gulzar25
Sorry. I do not get the exact picture. Can you please share a drawing or a screenshot of what you are trying to do ?
Balaji
Active Contributor
0 Kudos
Post 6 of 8
07-25-2013 04:42 AM in reply to: Balaji_Ram
Hi ,
I just want to know if for a block I get the geometricextents and plot the points.Is there any function or api to convert this block and set of points as one entity.I want to clone this points and block as a single entity.
Gulzar
254 Kudos
Post 7 of 8
07-25-2013 07:39 AM in reply to: gulzar25
The Point3d structure do not inherit from Entity neither from DBObject. A Point3d instance is only a geomeric object and cannot be added to an entity or cloned as DBObject instances.
You can create DBPoint instances, which are entities, from the Point3d and create a new BlockTableRecord which contains the source block reference and the DBPoint instances, then, insert it and clone it.
But you may also get the extents of the cloned object...
Or if you want to embed the extents (coordinates) of the source object to the cloned one(s), you can store them in the source block reference as attributes, xdata or extension dictionary xrecords before doing the cloning operation.
Gilles Chanteau
Active Contributor
0 Kudos
Post 8 of 8
07-25-2013 09:05 AM in reply to: gulzar25
I am not using the geometricextents function after clone is because in somecases i also do rotation on the block and when i try to retrieve the geometricextents it is giving me the extents for the block position before rotation.So i thought ill make point and block as single entity and clone.How do i make the points as attributes?
thanks
Gulzar
