.NET
CircularArc2d boundings
19 REPLIES 19
Message 1 of 20
1148 Views, 19 Replies
is there any way to obtain the boundings of an CircularArc2d object?
19 REPLIES 19
Message 2 of 20
Hallex
Try this one
             BoundBlock2d bb = arc.BoundBlock;
             Point2d minp = bb.GetMinimumPoint();
             Point2d maxp = bb.GetMaximumPoint();
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 20
in reply to: Hallex
Why the attacched polyline has minimum point negative?
MinimumPoint:(-0.0784183035384186,-0.0333440291205946),
MaximumPoint: (0.339761703945585,0.452622696834632)
Message 4 of 20
See Attached Picture
I am not getting a Negative Value
Message 5 of 20
fro2001 is your resuts based on my disegno2.dwg?
Here is my code that produce the output:
MinimumPoint: (-0.0784183035384186,-0.0333440291205946),
Document doc Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityResult per = ed.GetEntity("Select a polyline\n");
            if (per.Status == PromptStatus.OK)
                Transaction tr = db.TransactionManager.StartTransaction();
                using (tr)
                    DBObject obj = tr.GetObject(per.ObjectId, OpenMode.ForRead);
                    Polyline lwp = obj as Polyline;
                    if (lwp != null)
                        int vn = lwp.NumberOfVertices;
                        for (int i = 0; i < vn; i++)
                            SegmentType sg = lwp.GetSegmentType(i);
                            if (sg.ToString().CompareTo("Arc") == 0)
                                CircularArc2d ar = lwp.GetArcSegment2dAt(i);
                                ed.WriteMessage("ARC******************************************************\n");
                                ed.WriteMessage("Segment:" + i + "\n");
                                BoundBlock2d bb = ar.BoundBlock;
                                ed.WriteMessage("MinimumPoint:" + minp + ", MaximumPoint: " + maxp + "\n");
                            if (sg.ToString().CompareTo("Line") == 0)
                                LineSegment2d li = lwp.GetLineSegment2dAt(i);
                                ed.WriteMessage("LINE*****************************************************\n");
                                BoundBlock2d bb = li.BoundBlock;
Message 6 of 20
First look at the picture and see if that is what you want
This draws a rectangle around around the arc using the Entity.GeometricExtents
 [CommandMethod("PolyLineExtents")]
        public void PolyLineExtents()
            Document doc = Application.DocumentManager.MdiActiveDocument;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTable bt = db.BlockTableId.GetObject(OpenMode.ForRead) as BlockTable;
                    BlockTableRecord msBtr = (BlockTableRecord)bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForRead);
                    Entity ent = tr.GetObject(per.ObjectId, OpenMode.ForRead) as Entity;
                    Point3d min = ent.GeometricExtents.MinPoint;
                    Point3d max = ent.GeometricExtents.MaxPoint;
                    DocumentCollection docs = Application.DocumentManager;
                    AcadDocument acadDoc = (AcadDocument)doc.AcadDocument;
                    acadDoc.SendCommand("rec " + min.X + "," + min.Y + " " + max.X + "," + max.Y + " ");
                    tr.Commit();
Message 7 of 20
The rectangle is exacly what I'm looking for, but I can convert CircularArc2d to Entity?
Message 8 of 20
Here is a different one run on revision cloud (which is nothing but a polyine with arcs) I am not using the GetBoundBlockOf because I can't figure out how to even put the parameter in the right way.
This does not explode the actual object
I changed the current layer before I ran the command to be able to see it better.
See Attached picture
 [CommandMethod("PolyLineExtents2")]
        public void PolyLineExtents2()
                    DBObjectCollection dbObjColl = new DBObjectCollection();
                    ent.Explode(dbObjColl);
                    foreach (Entity entExplode in dbObjColl)
                        Point3d min = entExplode.GeometricExtents.MinPoint;
                        Point3d max = entExplode.GeometricExtents.MaxPoint;
                        ed.WriteMessage("\n Min: " + min.ToString() + "\n Max: " + max.ToString());
                    tr.Commit();
Message 9 of 20
Where is included "AcadDocument"? I got the error: The type or namespace name 'AcadDocument' could not be found (are you missing a using directive or an assembly reference?)
Also I have the same problem to convert CircularArc2d to Entity not the selection with "per.ObjectId" that works fine.
Message 10 of 20
Hallex
Include to References acmgdinternal.dll
Message 11 of 20
in reply to: Hallex
using Autodesk.AutoCAD.Interop;
reference
I was being lazy and using the rectangle command
Message 12 of 20
Splines will not work right so here a little work around if the spline is small the precision might be set to high and it does not convert it to a polyline it just uses it for the extents.
To see the difference try the first method on a spline then this one or draw a spline and do a SplineEdit or EditSpline then choose purge and when you select it you will see the control points it uses for its extents
[CommandMethod("BoundBoxSpline")]
        public void BoundBoxSpline()
            PromptEntityResult per = ed.GetEntity("Select a Spline\n");
                    BlockTableRecord btrMs = (BlockTableRecord)bt[BlockTableRecord.ModelSpace].GetObject(OpenMode.ForWrite);
                    Spline sp = tr.GetObject(per.ObjectId, OpenMode.ForWrite) as Spline;
                    Application.SetSystemVariable("PLINECONVERTMODE", 1);
                    sp.ToPolylineWithPrecision(99);
                    Point3d min = sp.GeometricExtents.MinPoint;
                    Point3d max = sp.GeometricExtents.MaxPoint;
                    tr.Commit();
Message 13 of 20
I do not know if you will have luck converting an entity to  part of entity
Message 14 of 20
I need to get StartPoint, EndPoint, Center for Arc and StartPoint, EndPoint for Line that compose a PolyLine.
Sorry for my inexperienced, but I don't know another way to decompose Polyline as Arc and Line:
Is there a better way to do this job and get StartPoint, EndPoint, Center, ent.GeometricExtents.MinPoint, ent.GeometricExtents.MaxPoint?
Message 15 of 20
Do not if you cared are not but some how I changed the the code for spline and it is wrong it should
                    Polyline pl = sp.ToPolylineWithPrecision(99) as Polyline;
                    Point3d min = pl.GeometricExtents.MinPoint;
                    Point3d max = pl.GeometricExtents.MaxPoint;
                    tr.Commit();
Message 16 of 20
For getting boundingbox of a polyline I use:
object oAcadObj = lwp.AcadObject;
object[] args = new object[2];
args[0] = new VariantWrapper(0);
args[1] = new VariantWrapper(0);
ParameterModifier pm = new ParameterModifier(2);
pm[0] = true;
pm[1] = true;
ParameterModifier[] modifiers = new ParameterModifier[] { pm };
oAcadObj.GetType().InvokeMember("GetBoundingBox", BindingFlags.InvokeMethod, null, oAcadObj, args, modifiers, null, null);
Point3d lowerLeftCorner = new Point3d((double[])args[0]);
Point3d upperRightCorner = new Point3d((double[])args[1]);
but my problem remain to find boundingbox of
Right now I solved for CircularArc2d with Radius and using it in combination with Center and for LineSegment2d with startpoint and endpoint.
Many thanks  fro2001
Message 17 of 20
Are you trying to get bounding box for each segment like the attached picture if so that is BoundBoxExplode which does not actually explode the object but you could iterate through and get all the points.
The picture has a polyine with arcs,lines, arcs and lines
Message 18 of 20
Yes, correct I'm trying to get it.
Message 19 of 20
bikelink
good solution but I'm not able to find this method from spline object!
ToPolylineWithPrecision()
Message 20 of 20
in reply to: bikelink
What year are you using?
I know it at least goes back to 2010.
”Boost
