.NET
Active Contributor
0 Kudos
Post 1 of 4
CHSPACE in Viewport programmatically?
299 Views, 3 Replies
08-13-2013 04:26 AM
Need to get inside the viewport in paperspace and run the command CHSPACE to bring some layers to the modelspace viewport. How to do this programmatically?
The
principle is as follows:
[CommandMethod("ChangeViewports")] public static void ChangeViewports() { Document document = Application.DocumentManager.MdiActiveDocument; Database database = document.Database; Editor editor = document.Editor; using (Transaction transaction = database.TransactionManager.StartTransaction()) { ObjectIdCollection objectIdCollection = database.GetViewports(false); foreach (ObjectId id in objectIdCollection) { Viewport viewport = transaction.GetObject(id, OpenMode.ForWrite) as Viewport; if (viewport.StandardScale == StandardScaleType.Scale1To1) viewport.Erase(); else { //Run this command CHSPACE viewport } } transaction.Commit(); } }
Thank you!
ADN Support Specialist
80 Kudos
Post 2 of 4
Re: CHSPACE in Viewport programmatically?
09-11-2013 01:36 AM in reply to: NayaraFJ
Hi
You can run a command using Document.SendStringToExecute. However I don't really understand the point of your question as same layers exist in both model and paper spaces, I don't see how you're going to use CHSPACE to import a layer from model to paper, this command only applies to entities...
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Active Contributor
4 Kudos
Post 3 of 4
09-12-2013 05:52 PM in reply to: NayaraFJ
Is this what you are after?
Selecting Model Space entities from Paper Space
matt worland
11 Kudos
Post 4 of 4
11-13-2013 02:06 AM in reply to: matt.worland
I need the same. I think he means copy objects (not just layers) from MS to PS. My need is to copy a selected closed polyline from MS to PS, suitably scaled to match the VP. [Selecting Model Space entities from Paper Space] just creates a selection set based on the viewport window. Not quite the same. Dale
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
