Check the drawing direction of a polyline
how can I find the drawing direction of a (closed) polyline with c#? Is there a property or method available or does one have a code snippet 🙂
TIA
Herbert
> snippet 🙂
Calculate the area (yourself), I think it's called Double Meridian
Distance. If the result is negative, your polyline is counterclockwise.
Terry
Terry,
Am Thu, 24 Sep 2009 15:22:17 +0000 schrieb Terry W. Dotson:
>> snippet 🙂
thank you for your hint,
this is working:
/// Methode GetAreaDMD( Polyline oPoly)
/// Berechnet die Fläche eines geschlossenen Polygons nach der
/// DoubleMeridianDistance-Methode
/// (-(x1*y2)-(x2*y3)-...(xn*y1)+(y1*x2)+(y2*x3)+...(yn*x1))/2
/// oPoly ist eine AutoCAD-Polylinie
/// Flächenwert als Double
/// nArea > 0 --> Fläche im Uhrzeigersinn gezeichnet
/// nArea < 0 --> Fläche gegen den Urzeigersinn gezeichnet
private double GetAreaDMD(Polyline oPoly)
int nPoints;
double nArea;
nPoints = oPoly.NumberOfVertices-1; // -1 weil Nullbasiert
nArea = 0.00;
for (int i=0; i < nPoints; i++)
nArea -= (oPoly.GetPoint2dAt(i).X*oPoly.GetPoint2dAt(i+1).Y);
nArea += (oPoly.GetPoint2dAt(i).Y*oPoly.GetPoint2dAt(i+1).X);
} // for ...
nArea -= (oPoly.GetPoint2dAt(nPoints).X*oPoly.GetPoint2dAt(0).Y);
nArea += (oPoly.GetPoint2dAt(nPoints).Y*oPoly.GetPoint2dAt(0).X);
return nArea/2;
} // GetAreaDMD()
Bye
Herbert
Herbert your formula has 1 too many loops.
You are getting the area of triangles and the total should be double the actual area of the pline.
The divide by 2 step is not needed for this function, so is not used
int count=pline.NumberOfVertices-1;
Point2d p1, p2;
for(int i = 0;i < count;i++)
p1=pline.GetPoint2dAt(i);
p2=pline.GetPoint2dAt(i+1);
Sum = Sum + ((p1.X * p2.Y) - (p1.Y * p2.X));
p1 = p2;
p2 = pline.GetPoint2dAt(0);
_gile
this one works with polyline arc segments too
{code}public double PlineAlgebraicArea(Polyline pl)
Point2d p0 = pl.GetPoint2dAt(0);
double area = 0.0;
double bulge = pl.GetBulgeAt(0);
int last = pl.NumberOfVertices - 1;
double tmpArea;
if (bulge != 0.0)
CircularArc2d arc = pl.GetArcSegment2dAt(0);
double arcRadius = arc.Radius;
double arcAngle = 4.0 * Math.Atan(bulge);
area += ArcAlgebraicArea(arcRadius, arcAngle);
for (int i = 1; i < last; i++)
area += TriangleAlgebricArea(p0, pl.GetPoint2dAt(i), pl.GetPoint2dAt(i + 1));
bulge = pl.GetBulgeAt(i);
if (bulge != 0.0)
CircularArc2d arc = pl.GetArcSegment2dAt(i);
bulge = pl.GetBulgeAt(last);
if (bulge != 0.0)
CircularArc2d arc = pl.GetArcSegment2dAt(last);
return area;
public double TriangleAlgebraicArea(Point2d p0, Point2d p1, Point2d p2)
return (((p1.X - p0.X) * (p2.Y - p0.Y)) - ((p2.X - p0.X) * (p1.Y - p0.Y))) / 2.0;
public double ArcAlgebraicArea(double rad, double ang)
return rad * rad * (ang - Math.Sin(ang)) / 2.0;
}{code}
Gilles Chanteau
GileCAD
GitHub
