.NET
SRSDS
Message 1 of 5 (281 Views)
Check if file open
281 Views, 4 Replies
03-15-2012 01:36 PM
I need to export data to an excel file but I need to check if the file is already open.
Searching the internet I found this but I don't know what "imports" to use to use to enable it.
    Public Function FileInUse(ByVal sFile As String) As Boolean
        If System.IO.File.Exists(sFile) Then
            Try
                Dim F As Short = FreeFile()
                FileOpen(F, sFile, OpenMode.Binary, OpenAccess.ReadWrite, OpenShare.LockReadWrite)
                FileClose(F)
            Catch
                Return True
            End Try
        End If
    End Function
Microsoft.VisualBasic.OpenMode.Binary
Distinguished Contributor
BMcAnney
Message 2 of 5 (279 Views)
Re: Check if file open
03-15-2012 01:42 PM in reply to: SRSDS
Looks like you need to import Microsoft.VisualBasic to get the FileOpen and FileClose functions. You may want to change them to use IO.File.Open and IO.File.Close though, to get away from the old VB syntax.
Brent McAnney
Hallex
Message 3 of 5 (264 Views)
03-15-2012 02:08 PM in reply to: SRSDS
I don't know what is the namespaces you use
in your program to work with Excel
Anyway you may want to try this function as well
   'Imports Microsoft.Office.Interop.Excel
    'Imports Excel = Microsoft.Office.Interop.Excel
    Public Function IsExcelFileOpen(xlapp As Microsoft.Office.Interop.Excel.Application, filename As String) As Boolean
        Dim isopen As Boolean = True
        Dim wbook As Microsoft.Office.Interop.Excel.Workbook
        Try
            wbook = xlapp.Workbooks(filename)
        Catch
            isopen = False
        End Try
        Return isopen
    End Function
~'J'~
SRSDS
Message 4 of 5 (263 Views)
03-15-2012 02:11 PM in reply to: BMcAnney
I added Imports Microsoft.VisualBasic but it didn't support the problem
OpenMode.Binary is the only one it has a problem with it seems.
arcticad
Message 5 of 5 (261 Views)
03-15-2012 02:22 PM in reply to: SRSDS
(defun botsbuildbots() (botsbuildbots))
