.NET
.NET
Valued Contributor
0 Kudos
Post 1 of 10
Changing the Color, Line type and Line weight using .Net
1299 Views, 9 Replies
03-08-2012 04:37 AM
How to change the Color, line type and Line weight for the Line using .Net.
One option:
Code solution is posted at  http://www.theswamp.org/index.php?topic=41172.msg463389#msg463389
// (C) CodeHimBelonga kdub
using System;
using System.Windows;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using StringToColorTest;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof (StringToColor))]
namespace StringToColorTest
public class StringToColor
[CommandMethod("DoIt")]
public void StringToColorTest_01()
Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
string colorString = AskUserForColorString(ed);
int colorIndex = ColorIndexFromString(colorString);
MessageBox.Show( "Color String : " +
colorString +
"\nTranslates to Integer : " +
colorIndex.ToString(),
"StringToColorTest_01");
public string AskUserForColorString(Editor ed)
PromptStringOptions strOpts = new PromptStringOptions("\nEnter Color: ");
strOpts.AllowSpaces = false;
PromptResult res = ed.GetString(strOpts);
if (res.Status != PromptStatus.OK)
return "ByLayer";
return res.StringResult;
public int ColorIndexFromString(string colorString)
int result = -1;
if (int.TryParse(colorString, out result))
result = ((result >= 0) && (result <= 256) ? result : 256);
else
try
MyColors colorIndex =
(MyColors) Enum.Parse(typeof (MyColors), colorString, true);
if (Enum.IsDefined(typeof(MyColors), colorIndex))
result = (int) colorIndex;
catch (ArgumentException)
AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
"Blooper !!");
return 256;
return result;
private enum MyColors
ByBlock = 0,
Red = 1,
Yellow = 2,
Green = 3,
Cyan = 4,
Blue = 5,
Magenta = 6,
White = 7,
Grey = 8,
ByLayer = 256
Valued Mentor
22 Kudos
Post 2 of 10
Re: Changing the Color, Line type and Line weight using .Net
03-08-2012 04:45 AM in reply to: chockalingam
What have you tried. ?
... and what documentation have you looked at ?
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Valued Contributor
0 Kudos
Post 3 of 10
03-08-2012 04:50 AM in reply to: KerryBrown
I tried the following
newentLine.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 190)
where, newentLine is a entity
This works,  but the issue is i want to change the color with a string input. I don't know how to do it
Valued Mentor
22 Kudos
Post 4 of 10
03-08-2012 04:56 AM in reply to: chockalingam
What strings do you want to use ?
Valued Contributor
0 Kudos
Post 5 of 10
03-08-2012 04:57 AM in reply to: chockalingam
I want to send the color as string
ex: red, white, ByLayer........
Valued Mentor
22 Kudos
Post 6 of 10
03-08-2012 05:18 AM in reply to: chockalingam
Sounds like a simple
if (..)
else if ( .. )
else if ( .. )
else if ( .. )
else ( .. )
construct would work for you.
... or you could use a dictionary if you're comfortable with that.
Depending on the source of the string you may be advised to change the case to a consistant format ....
Regards
501 Kudos
Post 7 of 10
03-08-2012 10:33 AM in reply to: KerryBrown
Or a (switch...), since color values are mutually exclusive.  The various case statements would associate the strings with the enumerated values, or ACI values.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
22 Kudos
Post 8 of 10
03-08-2012 04:26 PM in reply to: chockalingam
One option:
using System;
                                        colorString +
                return "ByLayer";
            int result = -1;
            else
                try
        "Blooper !!");
                    return 256;
            return result;
            ByBlock = 0,
            Red     = 1,
            Yellow  = 2,
            Green   = 3,
            Cyan    = 4,
            Blue    = 5,
            Magenta = 6,
            White   = 7,
            Grey    = 8,
            ByLayer = 256
Valued Contributor
0 Kudos
Post 9 of 10
03-08-2012 08:03 PM in reply to: chockalingam
Thanks for solution, this code helps me................
Valued Mentor
22 Kudos
Post 10 of 10
03-09-2012 05:49 PM in reply to: chockalingam
You're welcome.
It was an interesting technical problem.
Regards
