.NET
Active Contributor
laurie.comerford
Message 1 of 3 (222 Views)
Changing screen display between Plan and isometric
222 Views, 2 Replies
01-15-2012 01:40 AM
I'm trying to provide the user with some alternative vies of the drawing from within my application.
I picked up this code from an earlier post and have modified it to what I thought should work, but is has no effect on my screen display even after I exit from the form.  Searching the internet has not found a solution, so I need help again.
    Private Sub ComboBoxView_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBoxView.SelectedIndexChanged
        Dim myDwg As Document = Application.DocumentManager.MdiActiveDocument
        Dim myDB As DatabaseServices.Database = myDwg.Database
        Dim myTransMan As DatabaseServices.TransactionManager = myDwg.TransactionManager
        Try
            myTransMan.QueueForGraphicsFlush()  ' Have tried with and without this line
            Using myTrans As Transaction = myTransMan.StartTransaction
                Dim vpr As ViewportTableRecord = DirectCast(myTrans.GetObject(myDB.CurrentViewportTableRecordId, OpenMode.ForWrite), ViewportTableRecord)
                If vpr IsNot Nothing Then
                    Select Case Me.ComboBoxView.Text
                        Case "Plan"
                            vpr.SetViewDirection(OrthographicView.TopView)
                        Case "Front elevation"
                            vpr.SetViewDirection(OrthographicView.FrontView)
                        Case "Side elevation"
                            vpr.SetViewDirection(OrthographicView.LeftView)
                        Case "SW isometric"
                            vpr.ViewDirection = New Vector3d(1, -1, -1)
                        Case "NW isometric"
                            vpr.ViewDirection = New Vector3d(-1, 1, 1)
                        Case "SE isometric"
                            vpr.ViewDirection = New Vector3d(1, -1, 1)
                        Case "NE isometric"
                            vpr.ViewDirection = New Vector3d(1, 1, -1)
                    End Select
                End If
                myDwg.Editor.UpdateScreen()  ' Have tried with this line inside and outside the 'Using' section
                myTrans.Commit()
            End Using
        Catch ex As SystemException
            MsgBox(ex.Message)
        End Try
    End Sub
 I note that I have probably misguessed the direction vectors, but I can handle that by experiment once I get the screen updating.
Regards
Laurie Comerford
after modifying the vpr you have to tell the editor to update it's settings from the database. Try this:
myDwg.Editor.UpdateTiledViewportsFromDatabase()
HTH, - alfred -
Alfred.NESWADBA
Message 2 of 3 (215 Views)
Re: Changing screen display between Plan and isometric
01-15-2012 02:54 AM in reply to: laurie.comerford
HTH, - alfred -
Alfred NESWADBA
Active Contributor
laurie.comerford
Message 3 of 3 (196 Views)
01-15-2012 10:57 PM in reply to: Alfred.NESWADBA
Thanks Alfred,
That worked.
Regards
Laurie Comerford
