.NET
Changing position of AttributeDefinition
4 REPLIES 4
Ertqwa
968 Views, 4 Replies
Hello Forum,
I am trying to change the position of an AttributeDefinition in a block, but it nothing is changed:
foreach (ObjectId oidAttribute in btrBlock)
    adOrg = taTransaction.GetObject(oidAttribute, OpenMode.ForRead) as AttributeDefinition;
    if (adOrg != null)
            adOrg.UpgradeOpen();
            adOrg.Position = new Point3d(0, 0, 0);
            // Break;
            break;
    adOrg = null;
Commit();
 What is wrong? How do I change the position?
Thank you.
4 REPLIES 4
michael_vanhoose
in reply to: Ertqwa
Don't forget to go back thru the blockreferenceid's and update all the block references with the new difinition.
After you change the difinition insert a new block.  you will see the new position.  But, the old block references do not have that position.
khoa.ho
in reply to: Ertqwa
Attribute definition and reference are derived classes of DBText, which has two parameters to define its location (Position and AlignmentPoint). The alignment of the text may need to be updated after changing its content, which relates to middle/right horizontal/vertical alignment and font style. To update the text alignment, you need to manually set AlignmentPoint property or call attributeDefinition.AdjustAlignment(HostApplicationServices.WorkingDatabase)
-Khoa
Ertqwa
in reply to: michael_vanhoose
True, but my problem was that I had to change AlignmentPoint.
Thank you for the response.
Ertqwa
in reply to: khoa.ho
Yes changing AlignmentPoint does the trick.
Thanks!
”Boost
