.NET
.NET
Distinguished Contributor
SRayC
Message 1 of 6 (218 Views)
Changing from a user defined Coordinate System back to the WCS
218 Views, 5 Replies
02-24-2014 06:48 AM
Working in ACAD2012 via the COM object. Need guidence on how to change from a user defined coordinate system back to the WCS.
W7, VS 2012
Ray C.
mzakiralam
Message 2 of 6 (214 Views)
Re: Changing from a user defined Coordinate System back to the WCS
02-24-2014 07:09 AM in reply to: SRayC
SRayC
Message 3 of 6 (206 Views)
02-24-2014 07:59 AM in reply to: mzakiralam
This is what I am trying to do, but it fails.
AcadApp.ActiveDocument.ActiveUCS = AcadApp.ActiveDocument.UserCoordinateSystems.Item("World")
Any suggestions are appreciated.
Ray C.
ADN Support Specialist
Balaji_Ram
Message 4 of 6 (167 Views)
03-06-2014 11:19 PM in reply to: SRayC
Hello Ray,
There is no such UCS that is named "world".
To reset it to world, you can create a new UCS with appropriate coordinate system and set it as active.
            Dim org(0 To 2) As Double
            Dim oucs As AcadUCS
            Dim xpt(0 To 2) As Double
            xpt(0) = 1
            Dim ypt(0 To 2) As Double
            ypt(1) = 1
            oucs = acadDoc.UserCoordinateSystems.Add(org, xpt, ypt, "wcs")
            acadDoc.ActiveUCS = oucs
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Moderator
Alexander.Rivilis
Message 5 of 6 (149 Views)
03-07-2014 08:16 AM in reply to: Balaji_Ram
Hi Balaji!
But this is not real WCS but only UCS with name "wcs". I think that it's a different things.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Balaji_Ram
Message 6 of 6 (125 Views)
03-08-2014 06:54 PM in reply to: SRayC
Hi Alex,
You are right. But, the COM API is quite limited in what it can do.
I do not see any way to set it to World using the COM API other than creating a UCS that matches the WCS coordinate system.
If there is not specific reason for using the COM API, simply setting the "Editor.CurrentUserCoordinateSystem" to an identity matrix would set it to World.
Balaji
Balaji
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
