.NET
Changing from a user defined Coordinate System back to the WCS
5 REPLIES 5
SRayC
470 Views, 5 Replies
Working in ACAD2012 via the COM object. Need guidence on how to change from a user defined coordinate system back to the WCS.
W7, VS 2012
Ray C.
5 REPLIES 5
mzakiralam
in reply to: SRayC
SRayC
in reply to: mzakiralam
This is what I am trying to do, but it fails.
AcadApp.ActiveDocument.ActiveUCS = AcadApp.ActiveDocument.UserCoordinateSystems.Item("World")
Any suggestions are appreciated.
Ray C.
Balaji_Ram
in reply to: SRayC
Hello Ray,
There is no such UCS that is named "world".
To reset it to world, you can create a new UCS with appropriate coordinate system and set it as active.
            Dim org(0 To 2) As Double
            Dim oucs As AcadUCS
            Dim xpt(0 To 2) As Double
            xpt(0) = 1
            Dim ypt(0 To 2) As Double
            ypt(1) = 1
            oucs = acadDoc.UserCoordinateSystems.Add(org, xpt, ypt, "wcs")
            acadDoc.ActiveUCS = oucs
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Hi Balaji!
But this is not real WCS but only UCS with name "wcs". I think that it's a different things.
Facebook | Twitter | LinkedIn
Expert Elite Member
Balaji_Ram
in reply to: SRayC
Hi Alex,
You are right. But, the COM API is quite limited in what it can do.
I do not see any way to set it to World using the COM API other than creating a UCS that matches the WCS coordinate system.
If there is not specific reason for using the COM API, simply setting the "Editor.CurrentUserCoordinateSystem" to an identity matrix would set it to World.
Balaji
Balaji
”Boost
