.NET
Changing Current Layout
14 REPLIES 14
Message 1 of 15
GeeHaa
5732 Views, 14 Replies
Can anyone tell me why this code doesn't Change the current layout.
Dim acLayoutMgr As LayoutManager
acLayoutMgr = LayoutManager.Current
acLayoutMgr.CurrentLayout = "Model"
Thanks in Advance
14 REPLIES 14
Message 2 of 15
chiefbraincloud
in reply to: GeeHaa
The code I have is intended to activate a newly created layout tab, and ran in a command that has to be run from the Model tab, so I had to test it to see if it would activate the model tab and it worked fine. So the problem is not the code you posted.
Perhaps it has to do with where the code is running from (ie from code in a form class), but you'll have to provide more info for anyone to help.
If the code is as it is posted (always activates the Model tab, never any other tab) then you could try setting the system variable TILEMODE to 1 and see if that works.
Message 3 of 15
arcticad
in reply to: GeeHaa
try adding the session flag
Autodesk.AutoCAD.Runtime.CommandMethod("CommandName", Autodesk.AutoCAD.Runtime.CommandFlags.Session)
(defun botsbuildbots() (botsbuildbots))
Message 4 of 15
GeeHaa
in reply to: GeeHaa
Thanks for the response. I have command flags.session in there but for some reason it still doesn't change layouts. I was running it from a form so I tried putting it in the command routine,But it still doesn't change. It doesn't give an error either. Aside from the imports here is the code leading up to the change.
CommandMethod("PCL", CommandFlags.Session)
Public Sub PCL()
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
MsgBox("Current Layout = " + acLayoutMgr.CurrentLayout)
current layout is still "Layout1"
Thanks again.
Message 5 of 15
Hallex
in reply to: GeeHaa
Use Try..Catch to find a problem easily, i.e.
{code}
Public Sub PCL()
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Using doclock As DocumentLock = acDoc.LockDocument
Try
acTrans.Commit()
Catch ex As Autodesk.AutoCAD.Runtime.Exception
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
End Try
End Using
End Using
End Sub
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 6 of 15
Brad_Hamilton
in reply to: GeeHaa
I found it rolled back if you don't commit the transaction
If you leave out the commit, the layout changes, displays the layout name, and then checking okay rolls back
Message 7 of 15
GeeHaa
in reply to: GeeHaa
Locking the document did the trick. It changes the layout immediately even before the commit. I'm curious though, does Using Doclock lock the document just for this transaction and release it with the end Using statement?
Message 8 of 15
chiefbraincloud
in reply to: GeeHaa
Yes. the DocumentLock is disposed at the End Using.
You actually don't need a transaction to do this at all. You need the DocumentLock because you are running it from a form (which is why I mentioned form code earlier), but my code works fine without either a transaction or a DocumentLock, running from a CommandMethod in a Module.
Message 9 of 15
in reply to: GeeHaa
I still cannot understand the solution, i tried in many ways but it couldnt work. Can you please clarify much more
Tamer Mourad
Message 10 of 15
fieldguy
Show us what you have so far.
Message 11 of 15
in reply to: fieldguy
Here it is
<CommandMethod("t13")>
PublicSubT13()
'Change the drawing Number
MsgBox("Please place all the sheet under the this path C:\x and create an empty folder under the C:\1 that drawings will be placed in")
Dim direc AsString = "C:\x"Dim filecount AsInteger = System.IO.Directory.GetFiles(direc, "*.dwg").Length
Dim arrfile() AsString = System.IO.Directory.GetFiles(direc, "*.dwg")
Dim val AsInteger = InputBox("Please Enter the value you want to add to the text")
Dim adedo AsEditor = Application.DocumentManager.MdiActiveDocument.Editor
Try
Dim i AsInteger= 0
For i = 0 To filecount - 1
Dim currentFile AsString= arrfile(i)
Dim doc AsDocument = Application.DocumentManager.Open(currentFile, False)
Dim db AsDatabase= doc.Database
Dim newfil AsString= Replace(currentFile, Mid(Right(currentFile, 7), 1, 3), Mid(Right(currentFile, 7), 1, 3) + val)
newfil = Replace(newfil,
"C:\x\", "C:\1\")
Dim doclock AsDocumentLock= doc.LockDocument
Usingdoclock
Dim trans AsTransaction= db.TransactionManager.StartTransaction()
Using(trans)
Dim ly1 AsLayoutManager = LayoutManager.Current
LayoutManager.Current.CurrentLayout = "Layout1"
trans.Commit()
EndUsingEndUsing
doc.Database.SaveAs(newfil,
True, DwgVersion.Current, doc.Database.SecurityParameters)
doc.CloseAndDiscard()
Next
MsgBox(ex.Message & vbLf & ex.StackTrace)
Finally
MsgBox("Done")
EndTry
EndSub
Message 12 of 15
fieldguy
I assume you have this working from the posts here and in the other thread. Unless there is more to this, you don't need the database or a transaction.  You also don't need an editor that I can see.  This will do nothing if layout1 does not exist.
Using doclock
End Using
If you do need the editor, declare it after you open the currentfile, like "dim adedo as editor = doc.editor".
Command flags session is described in the developers guide - a good page to bookmark.  (http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a919382...)
If you have to do more batch file processing do a google search for the openfiledialog class.
Message 13 of 15
I do need the editor and transaction for the rest of the program, however when i added this line next to the command method it worked
Do you have any idea what does this line do?
By the way the hyperlink you attached is linking to something out of what i am asking for. R u sure from this bookmark
Tamer Mourad
Message 14 of 15
fieldguy
There is lots of help available on the internet.  The main idea is to search first.
Message 15 of 15
”Boost
