.NET
Change the current space
3 REPLIES 3
e.g.
728 Views, 3 Replies
Hello everybody,
I have a small application that zooms on an entity with specific properties. The problem is that if I am in paperspace and the entity is in model space, i cannot see the entity. How can I make the entity's space to become the current space?
e.g.
3 REPLIES 3
_gile
in reply to: e.g.
You can use the read/write CTAB sysvar.
Gilles Chanteau
GileCAD
GitHub
michael.robertson
in reply to: e.g.
If you know the name of the layout you can use
LayoutManager.Current.CurrentLayout = layoutName
If you don't know the layout of the entity you can use:
    Public Shared Function GetLayoutName(ByVal ent As Entity) As String
        Dim blockId As ObjectId = ent.BlockId
        Dim btr As BlockTableRecord = TryCast(ent.BlockId.GetObject(OpenMode.ForRead), BlockTableRecord)
        If Not btr.LayoutId.IsNull Then
            Dim layout As Layout = TryCast(btr.LayoutId.GetObject(OpenMode.ForRead), Layout)
            Return layout.LayoutName
        End If
        Return String.Empty
    End Function
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
e.g.
in reply to: michael.robertson
Thank you very much, it did help.
e.g.
”Boost
