.NET
Change text in attribute
5 REPLIES 5
1050 Views, 5 Replies
I am trying to change a text in attribute using vb.net.
I am using the following sub to update my attribute, if I use the message box I get correct information about the block, the attribute.tag I want to change and the text. The changes to my attribute are not saved.
Sub UpdateAttributeValue(ByVal BlockID AsObjectId, ByVal AttributeTag AsString, ByVal TextaStr AsString)
Using myTrans AsTransaction = BlockID.Database.TransactionManager.StartTransaction
Dim myBRef AsBlockReference = BlockID.GetObject(OpenMode.ForRead)
Dim myAttCollection AsAttributeCollection = myBRef.AttributeCollection
ForEach myAttRefID AsObjectIdIn myAttCollection
Dim myAttRef AsAttributeReference = myAttRefID.GetObject(OpenMode.ForWrite)
If myAttRef.Tag.Equals(AttributeTag, StringComparison.OrdinalIgnoreCase) = True Then
                    myAttRef.TextString = TextaStr
'MsgBox(myBRef.Name & " - " & myAttRef.Tag & " - " & myAttRef.TextString)
Exit For
End If
Next
            myTrans.Commit()
EndUsing
End Sub
5 REPLIES 5
truss_85
   I do not know what exactly your code problem but Try that it works fine
    Public Sub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname As String, ByVal AttTag As String, ByVal AttVal As String)
        Dim MyDb As Database = Application.DocumentManager.MdiActiveDocument.Database
        If BlockID.IsNull Then Exit Sub
        Try
            Using myTrans As Transaction = MyDb.TransactionManager.StartTransaction
                Dim myBlckRef As BlockReference
                Dim myAttColl As AttributeCollection
                Dim myBlckTable As BlockTableRecord
                myBlckRef = BlockID.GetObject(OpenMode.ForWrite)
                If myBlckRef.IsDynamicBlock Then
                    myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord, OpenMode.ForRead)
                Else
                    myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord, OpenMode.ForRead)
                End If
                If String.Compare(myBlckTable.Name, blckname, True) = 0 Then
                    myAttColl = myBlckRef.AttributeCollection
                    Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectId
                    Dim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReference
                    For Each myEnt In myAttColl
                        myAttRef = myEnt.GetObject(OpenMode.ForWrite)
                        If String.Compare(myAttRef.Tag, AttTag, True) = 0 Then
                            myAttRef.TextString = AttVal.ToString
                        End If
                    Next
                End If
                myTrans.Commit()
            End Using
        Catch ex As Exception
        End Try
    End Sub
Hallex
You have to open BlockReference ForWrite before,
~'J'~
chiefbraincloud
in reply to: Hallex
You do NOT have to open the BlockReference ForWrite.
If you were to happen to have the ObjectId of the AttributeReference stored (like from a previous operation maybe) you would not even have to open the BlockReference at all.  Opening the BlockReference ForRead is just fine for changing AttributeReferences.
Hallex
in reply to: chiefbraincloud
Sorry, have disagreed
OP asked about his wrong logic
He do not have mix both methods to Open object
In the function it is ObjectID.GetObject(blah..)
But in the calling Sub it would be use transaction.GetObject instead
Take a look ath this quick code, I had no problem with them on my A2010
        Sub UpdateAttributeValue(ByVal BlockID As ObjectId, ByVal AttributeTag As String, ByVal TextaStr As String)
            Using myTrans As Transaction = BlockID.Database.TransactionManager.StartTransaction
                Dim myBRef As BlockReference = DirectCast(myTrans.GetObject(BlockID, OpenMode.ForWrite), BlockReference)
                Dim myAttCollection As AttributeCollection = myBRef.AttributeCollection
                For Each myAttRefID As ObjectId In myAttCollection
                    Dim myAttRef As AttributeReference = DirectCast(myTrans.GetObject(myAttRefID, OpenMode.ForWrite), AttributeReference)
                    If myAttRef.Tag = AttributeTag.ToUpper Then
                        Exit For
                    End If
                Next
                myTrans.Commit()
            End Using
        End Sub
        <CommandMethod("chat")> _
        Public Sub chAttValue()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim peo As New PromptEntityOptions(vbLf & "Select block: ")
            peo.SetRejectMessage(vbLf + "You have to select block only!")
            peo.AddAllowedClass(GetType(BlockReference), True)
            Dim per As PromptEntityResult = ed.GetEntity(peo)
            If per.Status <> PromptStatus.OK Then
                Return
            End If
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim ent As Entity = TryCast(tr.GetObject(per.ObjectId, OpenMode.ForRead), Entity)
                Dim bref As BlockReference = TryCast(ent, BlockReference)
                If bref.AttributeCollection IsNot Nothing Then
                    UpdateAttributeValue(bref.ObjectId, "TAG1", "Value1")
                End If
                tr.Commit()
            End Using
        End Sub
Oleg
chiefbraincloud
in reply to: Hallex
I am afraid I don't understand your point.  This code works just fine (and has since 2007)
Public Sub SetAttTxt(ByVal BrefID As ObjectId, ByVal AttTag As String, ByVal Val As String)
    Try
        Using trans As Transaction = BrefID.Database.TransactionManager.StartTransaction
            Using Bref As BlockReference = trans.GetObject(BrefID, OpenMode.ForRead, False, True)
                Dim Alist As AttributeCollection = Bref.AttributeCollection
                Try
                    For Each AttID As ObjectId In Alist
                        If Not AttID.IsEffectivelyErased Then
                            Dim Ref As AttributeReference = trans.GetObject(AttID, OpenMode.ForRead, False, True)
                            If Ref.Tag = AttTag Then
                                Ref.UpgradeOpen()
                                Ref.TextString = Val
                                trans.Commit()
                                Exit For
                            End If
                            Ref.Dispose()
                        End If
                    Next
                    StdExEd(ex, "Error Setting Attribute Value" & vbCrLf)
                Finally
                    Alist = Nothing
                End Try
            End Using
        End Using
        StdExEd(ex, "Error Setting Attributes: Bad ObjectId or No Attribute Collection" & vbCrLf)
    End Try
End Sub
It also still works just the same using the ObjectId.GetObject method, and more importantly, the BlockReference is only opened for Read.
I honestly don't see what is wrong with the OP's code, but it is not that he is opening the BlockReference for Read.
”Boost
