How do I change the lineweight system variable
Pressing the command button puts <Lineweight > in the command line.
Is there some reference I should be looking to seach for these sort of things instead of troubling the forum?
The last problem I had to search for was to change lineweights
br.LineWeight = 0.35
should be:
br.LineWeight = LineWeight.LineWeight035
Solved by jeff. Go to Solution.
CELWEIGHT
Look at
Database.Celweight Property
As far as reference's in that situation look in helpfile in system variables for the one you want or search for keyword to find variable.
Then use the arxdoc.chm and type in Database on the index tab and see if Database has a property that matches the system variable name if not use Application.SetSystemVariable Method
Hi Jeff,
I played with that bit it didn't seem to change the variable.
I'm trying to change the line weight display which seems like an on/off thing.
The button sort of looks like a pair of sissors that toggles it.
Okay I saw nothing about display in first post
LWDISPLAY
<CommandMethod("LineWeightDisplay")> _ Public Sub LineWeightDisplay() Dim int As Integer = Application.TryGetSystemVariable("LWDISPLAY") If int = 0 Then Application.SetSystemVariable("LWDISPLAY", 1) Else Application.SetSystemVariable("LWDISPLAY", 0) End If End Sub
Also which is easier for me since I can not remeber what the buttons are is
right-click on one of the buttons and click 'Use Icons' to uncheck it and will change to previous style with letters
