.NET
Change layer
8 REPLIES 8
Message 1 of 9
617 Views, 8 Replies
Change layer
I developed a DLL in vs .net under vb.net. This DLL will change automatically the current layer to the layer '0' each time a command start. To do so I've done the following code:
Private Shared Sub m_doc_CommandWillStart(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.CommandEventArgs)
Dim curdb As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = curdb.TransactionManager
Dim myT As Transaction = tm.StartTransaction()
Try
curdb.Clayer = "0"
myT.Commit()
Catch ex As Exception
myT.Abort()
MessageBox.Show("An error ocurred...", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
Finally
myT.Dispose()
End Try
End Sub
Each time I execute a command this procedure is executed wihout an error, but only when the command 'line' is executed the current layer is acttually changed. When I execute the command 'mirror', 'dtext', etc the current layer doesn't change. I need help on this.
Thanks in advance for your attention,
Filipe Marcelino
8 REPLIES 8
Message 2 of 9
Please help!!!
I need a solution for this matter...
Message 3 of 9
hi again,
does anyone need some kind of explanation? Am I not being clear?
Filipe Marcelino
Message 4 of 9
Mikko
I think this is looking for an objectId not a string.
Maybe something like this?
Try
Dim layerId As ObjectId
Dim lt As LayerTable = myT.GetObject(curbdb.LayerTableId, OpenMode.ForRead)
layerId = lt.Item("0")
curdb.Clayer = layerId
myT.Commit() Message was edited by: Mikko
Message 5 of 9
Hi Mikko,
thanks for your reply. The same thing is happenning...maybe a SDK error?
Filipe Marcelino
Message 6 of 9
RonnieWilkins
Thrown together but working:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Public Class Class1
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Private CurrentDoc As Document
Try
Dim LayerId As ObjectId
Dim LT As LayerTable = myT.GetObject(curdb.LayerTableId, OpenMode.ForRead)
LayerId = LT.Item("0")
curdb.Clayer = LayerId
myT.Commit()
myT.Abort()
System.Windows.Forms.MessageBox.Show("An error ocurred...", "Error", System.Windows.Forms.MessageBoxButtons.OK, System.Windows.Forms.MessageBoxIcon.Error)
Finally
myT.Dispose()
End Try
End Sub
Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
CurrentDoc = Application.DocumentManager.MdiActiveDocument
'This will make the function only available to the document use used netload on.
'It's up to you to keep up to date as you switch drawings.
AddHandler CurrentDoc.CommandWillStart, AddressOf m_doc_CommandWillStart
End Sub
Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
End Sub
End Class
Ronnie Wilkins, Jr.
Message 7 of 9
hi,
is happening the same thing...
Message 8 of 9
RonnieWilkins
Then it has something to do with your settings.
The code I posted works with VB.NET 2005 and AutoCAD 2006. I tested it before posting.
Which version of VB.NET are you using?
Which version of AutoCAD?
Ronnie Wilkins, Jr.
Message 9 of 9
Hi again,
i'm using vb.net 2003 and autocad 2006. I don't understand why this isn't working? Do you have any other possibility to solve this issue.
Filipe Marcelino
”Boost
