.NET
Keith.Brown
Message 1 of 3 (251 Views)
Change font in tooltip text.
251 Views, 2 Replies
01-23-2012 08:09 PM
Does anyone know of a method to change the font inside the the tooltips generated when you hover over an object?? I have followed the tutorials from the developers specifically lab 6 which uses the point monitor event to append text to the tooltips when the aperture is hovering over an item in autocad. I would like to be able to make certain words bold but so far have not figured out how to do so. Any help would be appreciated. Thanks in advance.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Valued Mentor
fieldguy
Message 2 of 3 (228 Views)
Re: Change font in tooltip text.
01-24-2012 09:52 AM in reply to: Keith.Brown
According to >>this<< you need to create your own Tooltip class and a draw event.  I would like to see this if you decide to do it.
Active Contributor
cincir
Message 3 of 3 (197 Views)
01-25-2012 08:18 AM in reply to: fieldguy
But is there any chance to register your ToolTipDraw class to autocad for using it instead of itselfs.
