.NET
Change Drawing Editor Background color
7 REPLIES 7
Message 1 of 8
ericdaniel
2930 Views, 7 Replies
HI,
Is it possible to change the drawing editor background color via code?
Eric
7 REPLIES 7
Message 2 of 8
dan.glassman
in reply to: ericdaniel
Using COM Interop, you need:
Application.Preferences.Display.GraphicsWinModelBackgrndColor
and/or
Application.Preferences.Display.GraphicsWinLayoutBackgrndColor
-drg
Message 3 of 8
ericdaniel
in reply to: dan.glassman
Perfect,
Eric
Message 4 of 8
e.g.
is there other way to change the background, not using COM?
Actually I need to change the model background to different colors, to generate pictures used in a different application. If the pictures will have different colors(some black, some grey, etc) it would be easier to surf through them when finding the right one.
Any suggestions?
e.g.
Message 5 of 8
Alfred.NESWADBA
in reply to: e.g.
why don't you like to use COM?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 6 of 8
e.g.
It is ok with COM; it is only from curiosity to know the equivalent in API
e.g.
Message 7 of 8
fieldguy
in reply to: e.g.
There are several posts on this topic but no examples.  I looked in the vb forum and objectarx but could not find anything I really understand.  I have Option Strict On.
Why doesn't this work?  bgcolor changes from 0 to 1 but the background stays black - I want it to change to red.
Dim prefs As Autodesk.AutoCAD.Interop.AcadPreferences = CType(Autodesk.AutoCAD.ApplicationServices.Application.Preferences, Autodesk.AutoCAD.Interop.AcadPreferences)
Dim bgcolor As UInteger = prefs.Display.GraphicsWinModelBackgrndColor
msg += "color " & bgcolor & vbLf
prefs.Display.GraphicsWinModelBackgrndColor = CType(Autodesk.AutoCAD.Interop.Common.ACAD_COLOR.acRed, UInteger)
I am creating PNGs of all blocks in any dwg file.  I get a list of blocks, insert them into a new drawing 1 at a time, and plot using publishtowebPNG.pc3.  I want to allow the user to change the background color if they want.  The PNGs will be used in other places.
Message 8 of 8
fieldguy
in reply to: fieldguy
I should have kept looking.  This works.  Don't forget to set it back to the original value.
Dim curbg As Color = ColorTranslator.FromOle(CInt(prefs.Display.GraphicsWinModelBackgrndColor))
msg += "color " & curbg.ToString & vbLf
prefs.Display.GraphicsWinModelBackgrndColor = CType(ColorTranslator.ToOle(Color.Red), UInteger)
”Boost
