.NET
Change DIMBLK back to default
3 REPLIES 3
341 Views, 3 Replies
I need to change arrowheads of dimension style to default value. I find out from AutoDesk Exchange document this list:
""     closed filled
"_DOT"   dot
"_DOTSMALL"   dot small
"_DOTBLANK"   dot blank
"_ORIGIN"   origin indicator
"_ORIGIN2"   origin indicator 2
"_OPEN"   open
But I can not use "" to change back to default. Please help. Thank you so much
3 REPLIES 3
hgasty1001
Not sure, but SomeDim.SetDataBaseDefaults may help.
Gaston Nunez
in reply to: hgasty1001
I want to change dimension style. And DimStyleTableRecord didn't have SetDataBaseDefault() Method.
Virupaksha_aithal
Try this DevBlog http://adndevblog.typepad.com/autocad/2012/11/setting-different-arrow-heads-for-dimension-style.html . This blog shows how to set the different arrow heads for dimension style.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
”Boost
