I have several dwg files open within a single session of AutoCAD (dwg1, dwg2, dwg3, dwg4). Dwg4 is the last file that i opened so it's the one that is visible. What i am trying to do is to make dwg2 the one displayed on the screen.
I tryed looking into the DocumentManager object for methods, but was not able to find any.
Please adivse,
Thank you in advance,
-Jay
Solved by Alexander.Rivilis. Go to Solution.
DocumentCollection.MdiActiveDocument ?
Facebook | Twitter | LinkedIn
