.NET
Change Color, Line Type and Line weight without selecting any objects
12 REPLIES 12
Message 1 of 13
chockalingam
1218 Views, 12 Replies
I am trying to Change the Color, Line Type and Line weight in Properties Pallete without selecting any objects, but i don't know how to do this.
12 REPLIES 12
Message 2 of 13
Jeff_M
in reply to: chockalingam
Those are controlled by the drawing's Current sysvars.
CECOLOR
CELTYPE
CELWEIGHT
Message 3 of 13
chockalingam
Can you guide me, to use this in .net code
Message 4 of 13
kdub_nz
Untested
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// AcadApp.SetSystemVariable(string name, object value)
	AcadApp.SetSystemVariable("CECOLOR", "BYLAYER")
	AcadApp.SetSystemVariable("CELTYPE", "ByLayer")
	AcadApp.SetSystemVariable("CELWEIGHT", -1)
 Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 13
chockalingam
On using the above code,
AcadApp.SetSystemVariable("CECOLOR", "BYLAYER")- Results No Change
AcadApp.SetSystemVariable("CELTYPE", "ByLayer")- Results in "eInvalidInput" error
AcadApp.SetSystemVariable("CELWEIGHT", -1)- Results in "eInvalidInput" error
Message 6 of 13
kdub_nz
Works for me. ... see attached piccy.
Message 7 of 13
chockalingam
I don't know why it is not working for me.....
But i got the solution in another way, my solution code follows,
Using lock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Using acTrans As Transaction = acDoc.Database.TransactionManager.StartTransaction()
acDoc.Database.Celweight = LineWeight.LineWeight015
acDoc.Database.Cecolor = Autodesk.AutoCAD.Colors.Color.FromColor(Color.Red)
Dim acLineTypTbl As LinetypeTable
acLineTypTbl = acTrans.GetObject(acDoc.Database.LinetypeTableId, OpenMode.ForRead)
Dim sLineTypName As String = "Continuous"
If acLineTypTbl.Has(sLineTypName) = True Then
'' Set the linetype Center current
acDoc.Database.Celtype = acLineTypTbl(sLineTypName)
'' Save the changes
End If
acTrans.Commit()
End Using
End Using
Message 8 of 13
chockalingam
But the Only Issue in above code is we can't reback to "ByLayer"
Message 9 of 13
kdub_nz
Please clarify your last post. ??
And the code you posted is different to your initial question  ... but I see how I could confuse your intent.
Message 10 of 13
Why not, this code does not Work?
acDoc.Database.Celtype = "byLayer"
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 11 of 13
kdub_nz
in reply to: Alfred.NESWADBA
Alfred,
db.Celtype is an ObjectId
But this works for me too.
using AcadColor = Autodesk.AutoCAD.Colors;
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Database db  = doc.Database;
            db.Celweight = LineWeight.LineWeight015;
            db.Cecolor   = AcadColor.Color.FromColorIndex(ColorMethod.ByAci, 1);
            db.Celtype   = db.ContinuousLinetype;
            AcadApp.ShowAlertDialog("NOW WE'LL CHANGE THEM BACK.");
            db.Celweight = LineWeight.ByLayer;
            db.Cecolor   =  AcadColor.Color.FromColorIndex(ColorMethod.ByAci,256);
            db.Celtype   = db.ByLayerLinetype;
Message 12 of 13
chockalingam
Yes now i got the solution, This works for me.......
Message 13 of 13
Alfred.NESWADBA
in reply to: kdub_nz
>> Alfred, db.Celtype is an ObjectId
Ooops .... thank you (looked at the wrong place).
Nice weekend, - alfred -
Alfred NESWADBA
”Boost
