.NET
karea
Message 1 of 4 (222 Views)
Change block layer after insertio
222 Views, 3 Replies
07-31-2013 08:36 AM
Hi:
I've inserted a block into my drawing with this code:
Dim tmpDb As New Database(False, True)
        tmpDb.ReadDwgFile(nombrebloque, System.IO.FileShare.Read, True, "")
        Dim Transform As Matrix3d = Matrix3d _
                                    .Scaling(scale, Point3d.Origin) _
                                    .PreMultiplyBy(Matrix3d.Displacement(DispacementVector)) _
                                    .PreMultiplyBy(myed.CurrentUserCoordinateSystem)
        mydb.Insert(Transform, tmpDb, True)
and I would like to change some properties (layer, color,...) of the entities. (without modify the original block)
How can I access to these entities?
thanks..
Try this code, just change the path of your source drawing in the code
(assume your drawing is contains just separate objects like attribues, lines,and other
entities but not complete block itself)
 <CommandMethod("nombreblk", CommandFlags.Session And CommandFlags.Redraw)> _
Public Sub testExternalInsert()
Try
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim myed As Editor = doc.Editor
Dim mydb As Database = doc.Database
Dim sourceFileName As String = "C:\Test\NombreBloque.dwg" '<-- source file path
Dim blkId As ObjectId = ObjectId.Null
Dim nombrebloque As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(sourceFileName)
Using docloc As DocumentLock = doc.LockDocument
Using tr As Transaction = doc.TransactionManager.StartTransaction
Dim blkTbl As BlockTable = tr.GetObject(mydb.BlockTableId, OpenMode.ForRead, False, True)
If blkTbl.Has(nombrebloque) Then
Application.ShowAlertDialog("Block " + nombrebloque + " already exist. Exit.")
Return
End If
Dim myBtr As BlockTableRecord = TryCast(tr.GetObject(mydb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Using tmpDb As New Database(True, True)
tmpDb.ReadDwgFile(sourceFileName, System.IO.FileShare.Read, False, "")
blkId = mydb.Insert(nombrebloque, tmpDb, True)
tmpDb.CloseInput(True)
End Using
If Not blkTbl.Has(nombrebloque) Then
Application.ShowAlertDialog("Problem with import block. Exit")
Return
End If
Dim btr As BlockTableRecord = DirectCast(tr.GetObject(mydb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim bref As BlockReference = New BlockReference(Point3d.Origin, blkId)
'change some properties:
Dim scale As Double = 1.0
Dim scl As Scale3d = New Scale3d(scale)
bref.ScaleFactors = scl
bref.Rotation = Math.PI / 4
bref.LayerId = mydb.Clayer
bref.Color = mydb.Cecolor
myBtr.AppendEntity(bref)
tr.AddNewlyCreatedDBObject(bref, True)
Dim blkRec As BlockTableRecord = DirectCast(tr.GetObject(blkTbl(nombrebloque), OpenMode.ForRead, False, True), BlockTableRecord)
If blkRec.HasAttributeDefinitions Then
Dim attColl As AttributeCollection = bref.AttributeCollection
For Each attId As ObjectId In blkRec
Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
If TypeOf ent Is AttributeDefinition Then
Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition)
Dim attRef As New AttributeReference()
attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
attRef.Tag = attDef.Tag
attRef.TextString = attDef.TextString
Dim id As ObjectId = attColl.AppendAttribute(attRef)
attRef.AdjustAlignment(mydb)
tr.AddNewlyCreatedDBObject(attRef, True)
End If
Next
End If
tr.Commit()
End Using
End Using
Catch ex As System.Exception
Application.ShowAlertDialog(ex.Message.ToString() & vbLf & ex.StackTrace)
Finally
Application.ShowAlertDialog("See result.")
End Try
End Sub
Hallex
Message 2 of 4 (210 Views)
Re: Change block layer after insertio
07-31-2013 11:02 AM in reply to: karea
            Try
                            Return
                        End If
                        End Using
                            Return
                        End If
                                End If
                            Next
                        End If
                        tr.Commit()
                    End Using
                End Using
            Finally
            End Try
        End Sub
karea
Message 3 of 4 (178 Views)
08-01-2013 05:28 AM in reply to: Hallex
great! it runs!
thanks
Hallex
Message 4 of 4 (170 Views)
08-01-2013 11:57 AM in reply to: karea
Im happy to help
Cheers :smileyhappy:
