.NET
Change 3d Polyline data via Datatable
4 REPLIES 4
cschildmeier
1513 Views, 4 Replies
I have a form that will allow a user to select a 3d Polyline from a drawing, and have it populate a DataTable(DataGrid inside DataTable).  My seemingly simple task right now that I am struggling with is after changing the values in the DataGrid, pushing them BACK to Autocad(via Accept/Done button).  I've tried a lot of different things attemping to get this working with no luck.  I'm sure I'm missing something fundamentally.  Any help would be greatly appreciated.
#if ACAD
using AcRx = Autodesk.AutoCAD.Runtime;
using AcTrx = Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using AcClr = Autodesk.AutoCAD.Colors;
using AcWnd = Autodesk.AutoCAD.Windows;
using AcApP = Autodesk.AutoCAD.ApplicationServices.Application;
using AcP = Autodesk.AutoCAD.Interop;
#endif
namespace PolylineEditor
    public partial class Form1 : Form
        private static System.Data.DataTable vertexTable;
        public Form1()
            InitializeComponent();
            ChangeVertex();
            BindToDataGrid();
        static public void ChangeVertex()
            AcAp.Document doc = AcAp.Application.DocumentManager.MdiActiveDocument;
            AcDb.Database db = doc.Database;
            AcEd.Editor ed = doc.Editor;
            using (var trans = db.TransactionManager.StartTransaction())
                var options = new AcEd.PromptEntityOptions("\nSelect a 3DPolyline:");
                options.SetRejectMessage("That is not select a 3DPolyline" + "\n");
                options.AddAllowedClass(typeof(AcDb.Polyline3d), true);
                var result = ed.GetEntity(options);
                if (result.Status != AcEd.PromptStatus.OK)
                    return;
                var poly = (AcDb.Polyline3d)trans.GetObject(result.ObjectId, AcDb.OpenMode.ForWrite);
                var vertexClass = AcTrx.RXClass.GetClass(typeof(AcDb.PolylineVertex3d));
                vertexTable = new System.Data.DataTable("Vertices");
                vertexTable.Columns.Add("HandleId", typeof(long));
                vertexTable.Columns.Add("PositionX", typeof(double));
                vertexTable.Columns.Add("PositionY", typeof(double));
                vertexTable.Columns.Add("PositionZ", typeof(double));
                foreach (AcDb.ObjectId vertexId in poly)
                    if (!vertexId.ObjectClass.IsDerivedFrom(vertexClass))
                        continue;
                    var vertex = (AcDb.PolylineVertex3d)trans.GetObject(vertexId, AcDb.OpenMode.ForWrite);
                    vertexTable.Rows.Add(vertex.Handle.Value, vertex.Position.X, vertex.Position.Y, vertex.Position.Z);
        private void BindToDataGrid()
            dataGridView1.DataSource = vertexTable;
        private void toolStripButton1_Click(object sender, EventArgs e)
            ChangeVertex();
        private void btnApply_Click(object sender, EventArgs e)
        private void btnDone_Click(object sender, EventArgs e)
            Form.ActiveForm.Close();
4 REPLIES 4
Hallex
in reply to: cschildmeier
Hi cshildmeier,
Try compile all files in to project (class library include Form1)
Tested in A2010 only
Oleg
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
cschildmeier
in reply to: Hallex
It was a busy weekend Hallex, sorry for the late response. I'm going to give this a go now, thank you very much.
-Chris
cschildmeier
in reply to: Hallex
I have a lot of other functionality to add, and adding/moving things around on the form.  Other than that it works great.  You're a life saver sir.
Can't thank you enough for your help.
-Chris
Hallex
Smiley HappyYou're welcome, Chris
Knock my door again
Cheers 🙂
”Boost
