.NET
Amremad
Message 11 of 14 (221 Views)
Re: This is my completely code
06-28-2013 12:13 PM in reply to: DiningPhilosopher
Yes I can change the filter criteria at any time. but before start the selection
so , how can i after the selection method start >
see my completly code in the sub "handle_KeywordInput"  in selection case "Object" , i change what user what filter to selectionset do.
understand me?
_gile
Message 12 of 14 (139 Views)
06-30-2013 12:49 AM in reply to: Amremad
No, as DiningPhilosopher said, using Editor.SelectionAdded you can change the way you filter objects after the selection started.
Try this little snippet, it starts filtering lines and you can change the filtered entities to circles or polylines during the selection. The selection set keeps previously selected objects.
using System.Collections.Generic;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace SelectionSample
    public class CommandMethods
        // current keyword filter
        private string keyWord;
        [CommandMethod("Test")]
        public void Test()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            // (re)set default filter
            this.keyWord = "LIne";
            PromptSelectionOptions opt = new PromptSelectionOptions();
            opt.SetKeywords("[CIrcle/LIne/POlyline]", "CIrcle LIne POlyline");
            opt.MessageForAdding = "\nSelect objects or " + opt.Keywords.GetDisplayString(true);
            opt.KeywordInput += onKeywordInput;
            ed.SelectionAdded += onSelectionAdded;
            PromptSelectionResult psr = ed.GetSelection(opt);
            ed.SelectionAdded -= onSelectionAdded;
            if (psr.Status == PromptStatus.OK)
                ed.SetImpliedSelection(psr.Value);
        private void onKeywordInput(object sender, SelectionTextInputEventArgs e)
            this.keyWord = e.Input;
        private void onSelectionAdded(object sender, SelectionAddedEventArgs e)
            RXClass rxc;
            switch (this.keyWord)
                case "POlyline": rxc = RXClass.GetClass(typeof(Polyline)); break;
                case "CIrcle": rxc = RXClass.GetClass(typeof(Circle)); break;
                default: rxc = RXClass.GetClass(typeof(Line)); break;
            ObjectId[] ids = e.AddedObjects.GetObjectIds();
            for (int i = 0; i < ids.Length; i++)
                if (ids[i].ObjectClass != rxc)
                    e.Remove(i);
Gilles Chanteau
Amremad
Message 13 of 14 (118 Views)
07-01-2013 12:56 AM in reply to: _gile
wow   :smileyhappy:
i didn't think by this way , hahah ,
thanks mr _gile
Amremad
Message 14 of 14 (113 Views)
Clear Old Selection
07-01-2013 02:25 AM in reply to: Amremad
i solve 90% of my problems
no , how can i clear old selection after selection another block during selection set working
e.Remove(i)
just delete new added items , but i can't access of pervious selected item
