.NET
Active Contributor
WWFreeman
Message 1 of 14 (1,098 Views)
Catching Keyboard and Mouse Events
1098 Views, 13 Replies
03-07-2013 12:15 PM
Right now I am poking around to see whether there is possibility to catch events like KeyDown or MouseWheel.
I assume they would be available either on the Editor (AutoDesk.AutoCAD.EditorInput.Editor) object or somewhere under the Application (AutoDesk.AutoCAD.ApplicationServices.Application). I saw event handlers like Editor.Rollover but attaching to it didn't bring me far.
Has anyone a clue to where to look? Thanks!
Alright. Although I didn't actually apply that in the end, it is the answer to the initial question:
BlackBoxCAD wrote:
Forgive my curiosity, but while this is no Ctrl+MouseWheel Event handler, what's wrong with DoEvents(), and acedUsrBrk() to catch user input?
Quote:
"It's fairly common for developers to want to check for user input from time to time during long operations, especially to see whether the user wants to cancel the current activity. In VB you'd use DoEvents() to enable messages to be processed by the application's message loop and in ObjectARX you'd use acedUsrBrk().
So how to do this in .NET?
The answer is to use a message filter. This allows us to check on user-input events... we still call DoEvents, as with previous versions of VB, which allows user input events (such as keystrokes) to flow into our message filter function. We can then detect the events we care about, and filter them out, if necessary."
http://through-the-interface.typepad.com/through_the_interface/2007/02/index.html
DiningPhilosopher wrote:
Message filters can be added at any time during a plugin's life.
With a really strong notions of dangers of such approach:
If you use an IMessageFilter and check if certain keys are pressed, and what is currently happening in AutoCAD, you might be able to do what you need.  You can use System.Windows.Forms.ModifierKeys to check if CTR/SHIFT/ALT are pressed when you see a mouse wheel message, but you'd have to find a combination of keys that aren't used by AutoCAD with mouse wheel activity, if you don't want to step on that.
Thanks everyone.
Valued Mentor
DiningPhilosopher
Message 2 of 14 (1,092 Views)
Re: Catching Keyboard and Mouse Events
03-07-2013 12:36 PM in reply to: WWFreeman
There aren't any events that that correspond to keyboard and mouse input.
If you can say more about what you're trying to accomplish, there may be other ways.
Active Contributor
WWFreeman
Message 3 of 14 (1,083 Views)
03-07-2013 01:00 PM in reply to: DiningPhilosopher
Right... I had hoped I could use some free time to produce a command that would run pacman in the current document. Perhaps that's not entirely impossible but I'll leave it for some other time.
Particularly, I thought a nice-to-have is a layer walker, program logic that keeps only one layer turned on at a time, and uses a combination like ctrl+mouse wheel to run up and down through the list of layers.
From what I have seen, this might be possible to some extent through custom keyboard shortcuts but I wouldn't go there before being sure there is nothnig that can be done from ObjectARX' side.
Distinguished Mentor
BlackBox_
Message 4 of 14 (1,061 Views)
03-07-2013 02:08 PM in reply to: DiningPhilosopher
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
Valued Mentor
DiningPhilosopher
Message 5 of 14 (1,044 Views)
03-07-2013 09:27 PM in reply to: WWFreeman
You can use an IMessgeFilter to intercept windows messages, including mouse and keyboard events, but doing that continuously, as opposed to only doing some custom command would be extremely probelmatic since you can't tell what may be happening in AutoCAD from a windows message (for example, is there a dialog active, or is the user editing text, or is the user using the Properties Palette, etc.). so it would depend on if you wanted to do it during your custom command, or if you wanted to watch messages continuously while the user works in AutoCAD.
If it is the latter, see BlackBoxCadd's reply for a link to Kean's blog post showing how the IMessageFilter works.
Valued Mentor
DiningPhilosopher
Message 6 of 14 (1,043 Views)
03-07-2013 09:32 PM in reply to: BlackBox_
What's wrong with it depends on whether the need is continuous or if it is transient (e.g., only while a certain command is running).
That's why I asked the OP for more detail before going further..
Active Contributor
WWFreeman
Message 7 of 14 (1,039 Views)
03-07-2013 09:57 PM in reply to: DiningPhilosopher
Ok, I'll still have to go back to what BlackBoxCAD proposed.
I would like to have that continously present, but what I have come up with is that a command or a toolbar button can be created, that opens a modeless window. Then, this window can capture mouse wheel events and switch layers, regen the drawing...
If one wants to play ninja and hide this window from users, perhaps there is a way to make this window invisible and to make it follow the cursor until the first next click closes it. This would provide illusion that there is a command that does this.
But, otherwise, the window could be operating cross document and cross command until it is closed.
BlackBox_
Message 8 of 14 (1,032 Views)
03-07-2013 10:09 PM in reply to: DiningPhilosopher
My post was not in any way intended to challenge the request for more information; instead it was simply in the hopes of gaining some level of understanding behind the seemingly absolute response you originally offered.
You seem to possess a vast knowledge of the .NET API, and I just wanted to express my appreciation for your time in clarifying the topic further.
Cheers
BlackBox_
Message 9 of 14 (1,011 Views)
03-08-2013 08:37 AM in reply to: BlackBox_
"You seem to possess a vast knowledge of the .NET API, and I just wanted to express my appreciation for your time in clarifying the topic further."
... I thought I recognized you Tony (DiningPhilosopher, TT, TheMaster), by the accuracy, and completeness of the responses posted, which are always helpful, if not educational.
Cheers
Valued Mentor
DiningPhilosopher
Message 10 of 14 (999 Views)
03-08-2013 03:42 PM in reply to: WWFreeman
