.NET
Valued Mentor
AubelecBE
Message 1 of 3 (204 Views)
Catching a Righ Click but Autocad got nuts
204 Views, 2 Replies
09-04-2012 05:53 AM
Private Class JigFilter
        Implements System.Windows.Forms.IMessageFilter
        Private  WM_LBUTTONDOWN = As Integer = &H201
        Private WM_LBUTTONUP As Integer = &H202
        Private WM_RBUTTONDOWN As Integer = &H204
        Private WM_RBUTTONUP As Integer = &H205
        Public Function PreFilterMessage(ByRef m As System.Windows.Forms.Message) As Boolean _
                         Implements System.Windows.Forms.IMessageFilter.PreFilterMessage
            If m.Msg = WM_RBUTTONDOWN Then
                'Dim doc As Document = Application.DocumentManager.MdiActiveDocument()
                'Dim ed As Editor = doc.Editor()
                'ed.WriteMessage(vbCrLf + "Right Button pressed!!")
                If _toggleRotation = False Then
                    _toggleRotation = True
                    _posRotation = _position
                Else
                    _angle = Entite.Rotation
                End If
                Return True
            End If
            Return False
        End Function
    End Class
 He all.
I use a code for catching the right click mousse.
It work fine in my computer but i have installed on other Pc and when right click  occur autocad launch  a other command...   The command is random....
I dunno why ??
here the code New and the Run of my jig.
    '**** SUB NEW ************************
    Sub New(ByRef Doc As Document, ByRef tr As Transaction, ByRef db As Database, ByRef ent As Entity)
        MyBase.New(ent)
        Entite = Entity
        _filter = New JigFilter
        System.Windows.Forms.Application.AddMessageFilter(_filter)
        _Doc = Doc
        _db = db
        _tr = tr
        _angle = 0
        _txtSize = 12
_alignH = TextHorizontalMode.TextCenter _alignV = TextVerticalMode.TextVerticalMid _toggleRotation = False _toggleBold = False _toggleItalic = False Update() End Sub
    '**** FONCTION RUN *******************
    Public Function Run() As PromptStatus
        Dim stat As PromptStatus = PromptStatus.Keyword
        'While (stat = PromptStatus.Keyword)
        Do While (stat = PromptStatus.Keyword)
            Dim promptResult As PromptResult = _
                _Doc.Editor.Drag(Me)
stat = promptResult.Status Loop 'Raz eventHandler System.Windows.Forms.Application.RemoveMessageFilter(_filter) _filter = Nothing Return stat End Function
ADN Support Specialist
fenton.webb
Message 2 of 3 (158 Views)
Re: Catching a Righ Click but Autocad got nuts
09-10-2012 04:27 PM in reply to: AubelecBE
It might be easier to create a new Editor.PointMonitor
Editor ed =
      Application.DocumentManager.MdiActiveDocument.Editor;
    ed.PointMonitor +=
      newPointMonitorEventHandler(ed_PointMonitor);
and watch for the right click via the History property...?
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Valued Mentor
AubelecBE
Message 3 of 3 (140 Views)
09-11-2012 03:19 AM in reply to: fenton.webb
thank. I dont know how to use event handler.
I must learn this..
i changed the mouse click with key - and + and using this :
http://through-the-interface.typepad.com/through_the_interface/2012/09/a-handy-jig-for-creating-auto...
