.NET
.NET
New Member
0 Kudos
Post 1 of 4
Catch entities which intersected with a polyline
235 Views, 3 Replies
02-09-2014 02:46 AM
Hi All,
I have good experince with VB.Net, But i am new in prgramming for Autocad .
I had wrote code that catch all polylines on drawing, but now i have a  problem, i need to catch that entities (blocks in my case) which intersected  with each polyline.
any help please.
Thank you in advance.
Hi , to get intersection point between to entities you have to use 'entity.IntesectWith' function. With this function, you can get intersecting point. if for an entity if you get intersection point , you can add that entity in your list or array. you can have a look on below link where you can find how intersection point can be found between 2 entities.
http://forums.autodesk.com/t5/NET/Find-intersection-point-of-two-lines/m-p/4769671#M38812
30 Kudos
Post 2 of 4
Re: Catch entities which intersected with a polyline
02-09-2014 03:51 AM in reply to: MECODER
New Member
0 Kudos
Post 3 of 4
02-09-2014 09:33 PM in reply to: mzakiralam
Thank you very much Mr. mzakiralam
This is good try.
I know how to get intersection points using (IntersectWith) function, My problem is how to specify the type of the entity that intersects with the polyline.
30 Kudos
Post 4 of 4
02-10-2014 01:22 AM in reply to: MECODER
 entity.GetType() will help you to get entity type. you can also use below function.
Dim ent as entity = transaction.GetObject(ObjectId, OpenMode.Write)
If TypeOf ent is Polyline
'do as you want
End If
