.NET
Casting DBobject to entity
3 REPLIES 3
838 Views, 3 Replies
this piece of code always gives "invalidcode exception". I tried both Ctype and DIrectCast.
Dim currentEntity As Entity = Nothing
                            Try
                                ' currentEntity = CType(myT.GetObject(id, OpenMode.ForRead), Entity)
                                currentEntity = DirectCast(myT.GetObject(id, OpenMode.ForRead), Entity)
                            Catch exp As OverflowException
                                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("OverflowException")
                            Catch exp As InvalidCastException
                                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("InvalidCastException")
                            End Try
Attached is the full function, I am trying to read all the " coincidence constraints" in a  drawing
Thanks in advance!
3 REPLIES 3
Alfred.NESWADBA
Your loop scans through the BlockTable, so <id> represents the ObjectID for a BlockTableRecord. A BlockTableRecord is no entity (not derived from ...), so it can't be casted from DbObject to Entity.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thank you for the response . How do I go about converting a blocktable reference to a block entity?  I need the entity to find its dependencies.
Alfred.NESWADBA
It's difficult, if we don't use the wordingbased on the API.
If you want to search for the blockdefinition (= BlockTableRecord) then you can use your loop through the BlockTable as you do and verify the ObjectID or the Name or whatever you need to find the correct block-definition,
If you want to search for block-insertions (= BlockReference) then you might
  • use your <blocktablerecordobject>.GetBlockReferenceIDs to get all references in your drawing.
  • get the block-insertions could be to create a filtered selectionset (>>>click<<<).
HTH, - alfred -
Alfred NESWADBA
”Boost
